frequency changer ?
  • frequency changer ?
    Hi i have a device that runs off 9-12 volts and i can adjust frequency setting from 12khz to 38khz is there any way i could attach this to pcb to use,the machine im using runs at 13khz
    but its running on a coil made to run at 17khz ive fitted a phase control so my machine will except diff coils would it be possible to maybe get some use from this unit ?any ideas ?
    Depends on the design of the detector. Most designs have the ground circuitry calibrated to ferrite, and changing the frequency will mess up the calibration and ground balance won't work.
      tanks
