My custom m6!
  • My custom m6!
    I think the ideal metal detector does not exist.
    But sometimes you can do in way of doing something for us to get closer to that goal.
    This is my M6
    with 2 plates that I use:Eclipse White 6x10 (FANTASTIC!)Excelerator DETECH 18-inch (TO TEST, BUT PROMISES GOOD)
    Since the screw to the plate provided is not long enough for the 18-inch plate, I used a plastic screw of a water
    This is the wireless device PHILIPHS SBC HC8445that use, it is fed to the battery pack of metal steesso seen that goes to 12volt (NO DELAY IN CAP)
    So attached to the metal On 'M6 I put the volume in the sound controls on the box with a potentiometer and switch the backlight always on box controls
    A photo of the display on
    here a video to see the functioning of the whole
    M6 backlight
    The whole is fed with a BATTERY LIPO 3S 30C VOLTS 1.11 MAH 2450 (to which a short par to add the info a buzzer to warn of the minimum voltage to ricaricaricarla without damaging it)
    that the buzzer
    and video operation
    Lipo buzzer
    I do not let it attacked, but the attack during the search for status monitoring of the discharge batteroeWith the battery pack with a plug made from modeling, in case of emergency I can still use the original pack with the batteries stylus.In talo way, I'll never be on the ground with the batteries
    I created a cover to prevent moisture in the box to take command. I recycled a camouflage housing for telescopic
    In what way is your Eclipse White 6x10 FANTASTIC!
      for me is the best coil for beach
        Ok thanks
          What value pot did you use for the volume?
            470 ohm
              Originally posted by giangio1986 View Post
              470 ohm
              OK Thanks! I'm going to add one to my M6 too.
                please post photo after the mod
