BEACHSCAN PULSE
  • BEACHSCAN PULSE
    Does any one know the transmit frequency of Eric Fosters beach scan pulse detector.
    Re: BEACHSCAN PULSE
    Hi Dave,
    The Beachscan has a variable frequency dependent upon the delay setting. At minimum setting I believe the frequency is over 6 Khz.
    Eric uses a 555 timer that is then feed to a divide by 10 counter so at a minimum of 15 usec the frequency would be about 6.66 Khz.
    As the delay is turned up, the frequency lowers. I am not sure what the maximum delay is so I can't tell you the pulse frequency at that setting, but my guess is it is less than 2 Khz.
    Reg
