New projects
  • New projects
    take a look at http://www.pulsdetektor.de
    it has been updated
    lots of new projects
    Re: New projects (Language Translator?)
    I took a look at the site. It looks like it has been updated, but I couldn't get the specifics on some of the newly listed models to come up. Seems to be under construction. Does anyone know of a language translation plugin or something that would work with this site? (If such a thing exists.) The pictures are interesting but I don't have a clue what the text says.
    Russ_NY
      Hi Russ
      At the pulsdetektor web side you can find the finest PI detectors in the whole net (on earth) as "DIY Kit's" available in approx. 1 to 2 month time. The site is still under construction. Manufactures can only dream to have some of this features in there detectors. Here are some of the "hot" features. Active PI coil, real time discrimination, active filter, pulse isolation unit (PUI), conductance calculator, all parameters are adjustable and much more. I have heard that the high end detector kit's are able to detect a small gold coin in an iron basket buried half a meter (20 inch) deep in the ground.
      For the moment there are six smaller extreme good & easy to realize PI detectors projects available. All detectors from "Pulsi" (the inventor & developer) are working with the "3 O's" (Objekt im Objekt orten). The translation of the "3 O's" means. Identifying an object within in an object.
      More projects are coming soon. I hope that I could help you with this info.
      Best regards from Germany
      Chris
      www.pulsdetektor.de
