Sandbanks
  • Originally posted by Wahyu View Post
    modified from PI Polones
    https://www.youtube.com/watch?v=kbILR1xS_kg
    inside
    [ATTACH]38337[/ATTACH]
    modified driver mosfet and sample delay, sample window
    spec :
    Freq : 200Hz
    Pulse Width : 125uS
    Sample Delay : 25uS
    Sample Window : 50uS
    Coil : 302uH
    testing :
    [ATTACH]38338[/ATTACH]
    result:
    [ATTACH]38339[/ATTACH]
    Hello Wahyu,
    I would like to see a picture of the output of your pre-amp if you could post one. Thanks.
    • @ Mr Jaick
      can you please upload you board design layout, i would try it too, it seems to have more space for components
      @surfdetector
      no, and dont add delay option
      i achive very good performance with a chinese copy of lf357
      and a little optimised damping values
      very easy to get good detection with 38cm coil und a smal belt buckle made of bronze (40cm in air) with smooth sound and less chattering
      but i think about the pulsewidth mod, so i could go for boost mode while militaria hunting in german oderland
      • The Pi Polones is very similar to the Sandbanks.
        And without that transformer.
        • the 6Volt versionimpulsowy_wykrywacz_metali__1_.pdf
            @surfdetector
            I have added a trimmer on the PCB for the TX pulse width.
            My LF357 seems to stay in saturation for a long time, I would like to see a scope shot of another LF357 pin #6
            • i would take a minimal value (fixed resistor) in series with a variable resistor
              i can make a scope shot but only indoor
              • Originally posted by surfdetector View Post
                How did you choose the size of your damping resistor? Did you use the variable damping tool? I am thinking that it is not sized optimally.
                Cheers
                I was trying to use a damping tool, but i think i made it the wrong way, anyway
                since then i've been changing everything to get the optimal performance but not yet
                new information:
                coil 19 turns flat wind 0.5mm enameled with 2.5ohms DC resistance
                damping resistor 560 (is better for that coil)
                battery is 16v
                it detects a big 32cm steel tray at max about 110cm with a 50cm coil
                a big alloy coin at 20 or there about depends on the preAmp IC
                i tried many different ICs for pre amp but all of my LF357 chips are chattering and i can't adjust my threshold well
                i ordered a polones kit to compare it and see what's wrong, my board or components?
                  Yes yours is the better way with the series resistor.
                  A scope shot of the LF357 output would be great, no problem that it is indoors for me.
                  • [QUOTE=bernte_one;281395]@ Mr Jaick
                    I've been changing and modifying the pcb
                    now it's a bit messy but you can fix it and change it however you want:
                    Polones.zipi tried to find the old autosave ones but i couldn't sorry
                    • [QUOTE=Mr.Jaick;281408]
                      @ Mr Jaick
                      [ATTACH=CONFIG]53418[/ATTACH]i tried to find the old autosave ones but i couldn't sorry
                      What program opens the pcb file in the zip file ?
                      • [QUOTE=6666;281415]
                        WINRAR. https://rutracker.org/forum/viewtopic.php?t=5918606
                        Zockoyka
                        Стаж: 2 года 3 месяца
                        working like a charm, thank you so much
                        • Thanks KT, but I am asking what program is the pcb file for. not what opens the zip file.
                            Altium Designer
                              Altium Designer
                              Thanks I did not recognise the suffix, are you paying US$320 per month to use it
                                Originally posted by Mothough View Post
                                For now I'll try to build up the Surf PI design because I can do that without spending any money.
                                O_0
