vallon vmc1 error code
  • vallon vmc1 error code
    Hi, i need your help with my vallon vmc1
    I hope someone can help me with an error of my detector, is a vmc1 but
    When I turn it on, it starts and the seconds mark me a led code, which is 2 6 8 10 12 14, check the manual and say it can be an open circuit or the coil, my detector is like new, someone has passed it this?
    Originally posted by juliuss View Post
    .... the manual and say it can be an open circuit or the coil, ...
    The same with and without coil connected?
      Disconnect the coil and test it with an ohmmeter in order to see if there is the open circuit.
        Remove the search coil with the shaft and check the continuity at the seven pin connector. The centre pin is the live one to the coil via the internal cable, and all the outer pins are electronics ground. The test meter should read 3 - 4 ohms.
        Eric.
          Thank you for your support, tonight try to disassemble the detector and test the indicated measurements
