Surf pi VS geotech baracuda
    Originally posted by K tech View Post
    thanks qiazohi and yes i am building the rev A. Someone please tell me a subsitute for 2n5485
    An NTE451 is supposed to be the closest equivalent.
    A J113 should also work in this circuit, but the pinout is reversed compared to the 2n5485.
      reversed? can you put your datasheets for looking?
      tia
        I used the J113 as you suggested with success.
        The pinout between the two is the same at least on my ON Semiconductor samples.
          tia
          Attached.
            mine ones
              so is it reversed or is it pin compatible? I am confused
                So much for relying on my memory, Source & Drain are Interchangeable on the J113
                https://www.mouser.com/datasheet/2/3..._D-1811481.pdf
                  It is always a good idea to test transistors before soldering them to the PCB. TO-92 packages are particularly inconsistent in their pinouts. You might think that all manufacturers would use the same pinout for the same device, but you would be wrong. I have personally seen 3 different pinouts depending on whether they were manufactured in Europe, Japan, or the USA.
                    in original Bara one is set reversed but pcb works.
                      Okay thanks. I have ordered pcb , lt1054( were cheap on ebay compared locally I paid 6$ for 10) ,ne5534 and 79l05 and I will get the rest of the parts locally when the pcb arrives
