Delta Pulse
  • thx satdaveuk,but about cable shield how much is it (in dollar) and with the two female if the cable have from other side male,and how can i pay and get it,because i'm from Egypt.
    thanks
    • senifer xr71/delta pluse
      1. its value you see on the schematic. do not break your head.
      2. its value you see on the schematic. do not break your head.
      hi kt 315 many new member asked here how much deference in both detector i think there is need a new thread to latest 1-------- TX 2----------pulse width 3---------------man delay 4-secend delay
      • Originally posted by garah View Post
        thanks
        I don't follow your meaning.
        That looks like three different questions, so why won't you re-word your questions and make three different sentences for clarity. I have a hard time following your thoughts when you run them all together.
        Don't feel bad, I'm not trying to rag on you. I know translation between Arabic and English can be difficult. Looky here, I've have had to tell some American dude exactly the same thing: "Don't run five thoughts into one poorly spelled and poorly punctuated sentence, and then expect for anybody to understand your meaning".
        • ok porkluvr, no problem,i will explain...first the cable should have from each side either male or female or male and female right? let take that the cable have from each side male..ok? now i should buy the cable and the two female pieces (because we assumed that the cable have from each side male), my question; i want to buy the cable and the two pieces, how much is cable and two pieces price (in dollar)? the bottom line i wanna someone sell this kind of cable,who's that?
          and don't think that the English language difficult for me ,i'm studying electrical power engineering now and all my book in English if u know
          regards garah
          • I don't mean to offend your command of English, but just please remember to separate your thoughts so more people can more easily understand your meaning. (But you won't be alone if you don't.)
            Generally, I think you will have to buy your cable and connectors separately. I don't think you will find a ready-made cable but maybe you'll get lucky.
            Two connector possibilities: DIN and Mini-DIN connectors are cheap and (hopefully) readily available. You will need to have at least five (5) pins for the usual IB coil cable.
            You will most often find DIN and MINI-DIN connectors in either 180 degree or 270 degree configuration and you must choose one or the other. You cannot mix-and-match! These connectors are cheap but may not be very well weather resistant.
            The various MD manufacturers will generally use higher quality connectors than what you need or may be willing to pay for. They buy their stuff in bulk and get good prices, whereas you and I would pay dearly for the same materials IF AND WHEN we can find them. So, you must improvise with what is available! Hopefully somebody from your part of the world can give you some good leads because what might be available to me may not be available to you.
            Seems to me, cables and connectors is an area where it is pretty much left up to the individual builder to figure out what is possible!
            edit: OK this is supposed to be a Deltapulse thread so I don't know why I'm talking IB... let me out of here.
            • DP2 1x1m search coil
              Hi all.
              Today I made a 1x1m search coil.
              wire: 0,7mm
              winding: 14
              920 uH; 3,2 ohm
              Irf 740 is cold after long time.
              Works perfectly.
              30x30cm metal plate about 190-200cm detected
              • again give these pics, for Belif. he asked me to find him the sound.
                  LOL kt315 this picture should be logo for delta pulse
                  just joking
                  Cheers
                  • Hi everybody
                    Please i want to rebuild the delta pusle project, cause my first don't work perfectly, please can you give me the last updated documentation of the delta pulse detector
                    Cordialy.
                    • I ONLY was back now from a field I tested Delta Pulse again. Working too good! After my last shielding mod I described above. I did set 400 and 500 us of Pulse Width - there was NOT PROBLEM! Very well steady work.
                        • DP
                          Hello KT315,
                          I wonder what software you use for the front panel DP design. I am looking to give finishing touches to my DP. Do you have any templates by chance?...
                          looks great!
                          Kind Regards
                          Marius
                          • hi Marius,
                            I use FrontDesigner_3.0 translated/converted in Russian. it has 2,7mb installation EXE file. it is widespreaded in our part of world.
                            sincerely
                              • DP
                                Thank you so much KT315!!!.
                                Marius
