Delta Pulse
  • bro how i can test irf840 ?
    can you help me
    • Hi hadi-dindar
      when irf840 is hot -
      -what specification of coil? what resistance?
      -Be sure of value R5 /1w?
      best time
      j.
      • These questions are correct! My little coil 27 turn (0,5 mm cu wire with laquer insulation) 450uH, ca. 3 ohm resistant, the big one from UTP cable (400 mm diameter), ca. 550 uH, 3x8 turn. Works all well. IRF not warm.
        http://www.geotech1.com/forums/showt...a-Pulse/page10
        From this page are wery interesant informations. Not easy but their perusal is useful. Takes 1-2 days, but is repaid. 1-2 components escape.
        • Originally posted by jap View Post
          Hi hadi-dindar
          best time
          j.
          ok r6 and r7 are 680r 1w
          i have 35cm and 3.4 ohm ( wire 0.8 with cat5 cable )
          • Hi hadi-dindar
            ( wire 0.8 with cat5 cable ) (cat5 cable not 0.8 is 0.5mm)
            in dp2
            R5=1.2K~2.2k /1w
            R6=680 , R7=15K
            -IF coil resistance 3.4 ohm add in series to coil 2.2/1w
            best time
            j.
              Hi hadi-dindar
              R5=680~1.2k /1w
              r6=1k
              best time
              j.
              bro i have one 1.5k 2w resistor /
              can i add this resistor inistate of 680ohm with 3.4 ohm coil ?
              • Hi hadi-dindar
                R5=1.2K~ 1.5k ~ 2.2k /1w
                r6=680,R7=15K
                -IF coil resistance 3.4 ohm add in series to coil 2.2 ohm/1w
                best time
                j.
                • Hi hadi-dindar
                  In this case it is necessary that your coil is 6.2 Ohm
                  as he explained our dear Jap
                  And checked the transistor BC 557 I had this problem
                  made to change the IRF 740 by another 840
                  best time
                  N.
                    Hi hadi-dindar
                    r6=680,R7=15K
                    best time
                    j.
                    hi my dear . jap
                    my r5 now is 1.5k 2w and r6=680ohm 1w
                    but not work
                    and current in circuit is zero
                    and my coil ohms is 3.4 ohm
                    3.4 ohm is match with informations ( r6 and r5 ) ?
                    • Prepare a picture from IRF neighbourhood. I revised it the sch. It may be IRF only according to me, if without a coil not short-circuit.
                      My little coil big like Garett coil. http://n1.vatera.hu/photos/6a/2f/9d16_1_big.jpg
                      450uH, 3,4 Ohm and work fine.
                      The frequencies is ca. 500Hz. If the freq. low the IRF warming with low resistant coil.
                      • Does anyone have parts placement sheet or schematic for the 7 knob Turkish delta pulse? I found the 6 knob but it's not close enough.
                        • Originally posted by sparky View Post
                          [ATTACH]21305[/ATTACH]
                          Look it.
                          Green circle for Plot or Knob
                          Red Circle Connection LCD with PIC 18f252
                          Best time
                          N.
                          Delta pulse _ema (1).pdfClick image for larger version
                          • Hi hadi-dindar
                            -Is irf840 is hot now ?
                            -change Q1=IRF740 OR 840
                            -change D1=UA556
                            -Tested and check T9
                            best time
                            j.
                            • hi jap.
                              i changed 840 and 556 and t9
                              but Not true my dear.
                              can you help my to crate a pefrect coil for my set ? and i have only 680ohm . 1w nad 1.5k 2w resistance for r5,r6 .
                                Hi hadi-dindar
                                -coil 40 cm 0.5 mm 24 turn =adsl cat5 3x8turn ...2.6 ohm
                                Put pictures of the project
                                best time
                                j.
