Delta Pulse
  • Originally posted by Nikolov View Post
    Good work Brabra congratulations
    What coil you use? and what is the depth
    Tnks
    Coil is not ready
    • Hello everyone. I have built the delta pulse 2 but not have the correct file for hex of discrimination. you can give it to me;
      • Hi pigeon
        -for only red led work it is true--the green led work when descrimination when conection to delta .
        -(reprogramming hex and test)
        - test conection pin of data may the error from.
        - if lcd conection is OK (in that case must lcd light ).
        Hi sakis1
        -For HEX file for the descrimination read reply #1689.
        best time
        j.
        • hi jap> this file needs the code (rar is locked) regards
          • Originally posted by sakis1 View Post
            hi,,,> u write.
            best time
            j.
            • no it can not open the downloaded file/locked or empty/you can upload it for me;Even as τχτ*
                Hi sakis1
                HEX file for the descrimination in TEXT
                best time
                j.
                • Originally posted by jap View Post
                  Hi pigeon
                  Hi sakis1
                  best time
                  j.
                  ok jap.
                  thank you very much
                  pigeon.
                  • OK
                    25cmX35cm alu sheet on 110cm
                    alu can 1L on 75cm
                    coin on 30cm --for coin I have Spectrum Eagle
                    THE END
                    P.S. Thank you very much FRIENDS
                      Hi sakis1
                      best time
                      j.
                      THANKS
                        OK
                        alu can 1L on 75cm
                        THE END
                        Hi Nikolov
                        good,,, if u result with 35cm coil ,,,,u have good coil+dp
                        best time
                        j.
                        • Thanks Jap for generous assistance
                          this is my Delta without 32cm coil
                          this is with previous c4 and c6 ceramic caps
                            [ATTACH=CONFIG]21650[/ATTACH]
                            [ATTACH=CONFIG]21651[/ATTACH]
                            Hi Nikolov
                            Good work
                            • Good work! Congratulations!
                              Please send me the LCD schematic (the discriminatior type).
                              This is my Delta.
                              Thanx!
                              • Sorry. I found it. #1474
