Delta Pulse
  • hi kt315
    this pcb is correct. this is my best i'm still a beginner
    thank you
    best time
    P.
Name:	pcb delta pulse k315 ok.png
    • GEOTECH SERBIA English version.rar
      • top side
          [ATTACH]27558[/ATTACH]
          Orbita, referred to with this?
          Jose
          • I do not understand?
            • Orbit, he means asked this your HEX file for what? DP is fully analog detector, no need in PIC and ATMEL HEX files in it.
              • thanks kt ! In some posts is japp allegedly put hex fail English version for discrimination at which thought
                to change the welcome sign not the first and last name authors for example delta pulse as this is and as demo version I put hex code in which when pressed Home message lcd ,
                but I was irritated which were allegedly put the English version I have changed hex cod that much more work .
                and we have a way to hex cod working as the full version .
                • -inscription on the LCD GEOTEC SERBIA
                  So this is the same HEX FAIL DELTA PULSE 2 diskriminacion !
                  • Even when you buy full version from turkey writes name and surname authors and teams !
                      revision of the schematic. in P-CAD 2006
                      [ATTACH]27502[/ATTACH]
                      hi
                      how much it ?
                      can detect 15*15 on 5meter ???
                      • hallo ... which lf357 pin6 signal it correct ? 1. or 2. Click image for larger version
ID:	338697Click image for larger version
                          Hi Orbit
                          It seems that your hex file cannot work in the the simulation program because there are incorrect checksums at the end of hexadecimal lines 7 down to line 18. So impossible to check if program will work as Demo OR Full (that is, without 200 on/off cycles).
                          Please upload the corrected Geotech Serbia English version that can work, otherwise it's a waste of everyone's time.
                          Ciao
                          Speedy_G
                          • Originally posted by aaksts86 View Post
                            hallo ... which lf357 pin6 signal it correct ? 1. or 2. [ATTACH]27595[/ATTACH][ATTACH]27596[/ATTACH]
                            do you see what there written on R5????
                            • circuit diagram
                              • GEOTECH 1 TEHNOLJOBI EKIBI DEMO YELZDIMIR KALAN KALAN.rar
