Delta Pulse
  • Dont burn the Diodes, and better switch off the mosfet...
    Connect the pin 7 of 556 DIRECT to -BATT, not to -E,
    C1 and C3 too.
    From pin 9 (out 556) dont connect direct to pin 5 (input 453 ,but trough resistor 6K8,
    so there are no problem for the 4538 , if you connect direct you will burn the 4538.
    So Delta Pulse is modificated to ...normal operation.
    Sorry about my English, im too lazy to use translator today..
    greetings from Greece.
      [ATTACH]37789[/ATTACH]
      [ATTACH]37790[/ATTACH]
      pls can you post other Pictures with better contrast of tracks and mass plane can only see pinky light red and red
      i am interested to adapt your design to sprint layout, any gerber files can help too
      thx
      • thank you Xtrem for nice suggestion. i will check your mod and will do changes in the layout in following batch (you know maybe new batch ordering only to every new year LOL!)
        • Hi kt315, check the mod, if you "see" carefully ,you see the opportunity to make very easy a 24V Version, you need then only a 7912 for the whole circuit(exept 556 and mosfet) a 7812 (for 556 timer driver) and a little circuit that connect the 556 to 4538 and 4066 (level shifter) ...4 or 2 transistors, i did not try the 24V version.
            thx
            ufff,,, i am not able to delete top silk layer... write me what color you prefer for silk and i ll remake.
            top.rar
            • will upload some videos with speedy translate.
              Search by plowing, using aerial photography, GPS and the deeper.
              Often there are questions about how to understand the depth signal or not,
              so we decided to shoot the video found on the dugout.
              An autopsy will reveal what's down there.
              • did dig up the signal from the previous video,
                it turned out that this is really the dugout,
                caught in one of the corners, where there was a stove.
                • kt315 master
                  most suitable what should be the values of the coil
                  thanks
                  • Nice. Thank´s a lot for the info´s and the video.
                    • Originally posted by andon80 View Post
                      kt315 master
                      thanks
                      reformulate your request in more international english form pls. i can not grasp what you write/want.
                        I think he is asking for the coil specifications.
                        • 1mx1m coil has to have 12 turn of wire. measured value has to be 350-450uH.
                          • Comment
                              [ATTACH]37845[/ATTACH]
                              all ok thx, solder stop was problem
                              but black white picture is ok
                              • 1x1 coil with 12 windings (1mm2 diameter of wire) - this is my coil parameters and it gives 650uH.
                                My guess is 10 windings of 0.75mm2 wire will give closer to 400uH results and I've reduced the cross section because lower number of turns will also give lower resistance of the coil (around 1.5 Ohms which is too low), you may need to add 1-2 Ohms resistor at 3-4 Watts.
