Delta Pulse
  • I share with you Eclipse, that it is necessary to add a series resistance of 1 to 2 ohms, for a better operation of the coil of 1 X 1 m.
    The total resistance measured with an ohmmeter should be 2 to 3 ohms.
    Resistance of the coil, less than 2 ohms, makes the DP unstable.
    Jose
    • thanks kt315what should be the best ohm
      • did dig up the second half of the dugout fromh the previous video.
        • We arrived at the place, saw on the digging of the pit,
          a close signal was found from them, more precisely, two,
          and deep and horse around.
          0:58 a work by corner, some kinda pinpointing. take attention on this trick.
          • i changed a date on sch you see its last.
            • work with the frame at positions of 66 Army... offensive of the Red Army in January 1943 to a height 147.6 near Orlovka)) found a shallow trench to discharge military iron and a German soldier ...
              a good example of the different signal, location and purpose of use of a visual of the frame on the fields.
              nice view ��
              • Comment
                • Comment
                  • Awesome videos from prospecting kt315
                    • BOM file
                      BOM file
                      DP_BOM.txt
                      DP_BOM.pdf
                      • Can somebody post Crazy star v1 files?
                        As i heard, this is single sided board of DBP2010.
                        • hello cdi,
                          best you ask sinko, as i know the metal detector is nor more in production, maybe you can get the layout files
                          i have all about this project but i had to promise to not share it anywhere during he open his shop
                          but i thing he has newer thinks, so best ask him i think he can give it away for us for improoving and testing
                          i suppose it is a clone of design from sasho pi, and one of the reasons sasho stops to share detailed infos about his project here...
                            hello cdi,
                            Thank you Bernte_one.
                            • hi for all .i have built delta pulse2 (this version) it works well but the problem that i detect all metals except gold at any distance.can any one help me to solve this problem ?thank you in advance
                              • Have you tried setting your delay to minimum, and adjusting sensitivity accordingly?
