Delta Pulse
  • Originally posted by Andrei73 View Post
    Здравствуйте КТ315.
    Английски не знаю.
    Хотел я Вам в личико написать, но почему то не рашрешает.
    Как с Вами контактоваться, где написать?
    Спасибо.
    • after first message written you can write in PM.
      • Healthy pcb circuit existing?
        • I love only GOLD
          • Originally posted by ahcene2035 View Post
            we need 3meters depth on 15x15cm gold plate.
            • 4 meters are better
              • guys who bough my board... i do not need your project pics sent on my email, i need your pics HERE.
                HERE i mean the forum. again I DO NOT NEED YOURS PICS but people NEED. put them here, be more adequate.
                all the best
                • this mod increases reaction of SAT speed if you need to do it. ossama mod.
                  • Awesome
                    • thank....
                      • one more question. when the coil passes over the target, a signal (sound) appears, after the passage the signal drops, but then in a clean place it appears and falls again. That is, recovery is delayed. Such an effect, as if there is a smaller target. How is it possible to remove it .....?
                        • answered many times! your enclosure is NOT SHIELDED against ELECTROSTATIC FIELDS. you DID IGNORE ALL MY WARNINGS.
                          I SAY AGAIN YOU MUST DO THE SHIELDING! MUST DO IF YOU DO NOT WANT TO DO!
                          MUST DO IF YOU DO NOT LIKE TO DO!
                          • suka kak vy menia dostali!!!
                            From Wikipedia, the free encyclopedia
                            Jump to navigationJump to searchFor the science of static charges, see Electrostatics.
                            Contact with the slide has left this child's hair positively charged so that the individual hairs repel one another. The hair can also be attracted to the negatively charged slide surface.
                            static electricity is an imbalance of electric charges within or on the surface of a material. The charge remains until it is able to move away by means of an electric current or electrical discharge. Static electricity is named in contrast with current electricity, which flows through wires or other conductors and transmits energy.[1]
                            A static electric charge can be created whenever two surfaces contact and separate, and at least one of the surfaces has a high resistance to electric current (and is therefore an electrical insulator). The effects of static electricity are familiar to most people because people can feel, hear, and even see the spark as the excess charge is neutralized when brought close to a large electrical conductor (for example, a path to ground), or a region with an excess charge of the opposite polarity (positive or negative). The familiar phenomenon of a static shock – more specifically, an electrostatic discharge – is caused by the neutralization of charge.
                            Contents
                            Causes
                            Materials are made of atoms that are normally electrically neutral because they contain equal numbers of positive charges (protons in their nuclei) and negative charges (electrons in "shells" surrounding the nucleus). The phenomenon of static electricity requires a separation of positive and negative charges. When two materials are in contact, electrons may move from one material to the other, which leaves an excess of positive charge on one material, and an equal negative charge on the other. When the materials are separated they retain this charge imbalance.
                            Contact-induced charge separation
                            Styrofoam peanuts clinging to a cat's fur due to static electricity. The triboelectric effect causes an electrostatic charge to build up on the fur due to the cat's motions. The electric field of the charge causes polarization of the molecules of the styrofoam due to electrostatic induction, resulting in a slight attraction of the light plastic pieces to the charged fur. This effect is also the cause of static cling in clothes.
                            Main article: Triboelectric effect
                            Electrons can be exchanged between materials on contact; materials with weakly bound electrons tend to lose them while materials with sparsely filled outer shells tend to gain them. This is known as the triboelectric effect and results in one material becoming positively charged and the other negatively charged. The polarity and strength of the charge on a material once they are separated depends on their relative positions in the triboelectric series. The triboelectric effect is the main cause of static electricity as observed in everyday life, and in common high-school science demonstrations involving rubbing different materials together (e.g., fur against an acrylic rod). Contact-induced charge separation causes your hair to stand up and causes "static cling" (for example, a balloon rubbed against the hair becomes negatively charged; when near a wall, the charged balloon is attracted to positively charged particles in the wall, and can "cling" to it, appearing to be suspended against gravity).
                            Pressure-induced charge separation
                            Main article: Piezoelectric effect
                            Applied mechanical stress generates a separation of charge in certain types of crystals and ceramics molecules.
                            Heat-induced charge separation
                            Main article: Pyroelectric effect
                            Heating generates a separation of charge in the atoms or molecules of certain materials. All pyroelectric materials are also piezoelectric. The atomic or molecular properties of heat and pressure response are closely related.
                            Charge-induced charge separation
                            Main article: Electrostatic induction
                            A charged object brought close to an electrically neutral object causes a separation of charge within the neutral object. Charges of the same polarity are repelled and charges of the opposite polarity are attracted. As the force due to the interaction of electric charges falls off rapidly with increasing distance, the effect of the closer (opposite polarity) charges is greater and the two objects feel a force of attraction. The effect is most pronounced when the neutral object is an electrical conductor as the charges are more free to move around. Careful grounding of part of an object with a charge-induced charge separation can permanently add or remove electrons, leaving the object with a global, permanent charge. This process is integral to the workings of the Van de Graaff generator, a device commonly used to demonstrate the effects of static electricity.
                            Removal and prevention
                            Main articles: Antistatic agent and Antistatic device
                            A network card inside an antistatic bag.
                            An antistatic wrist strap with crocodile clip.
                            Removing or preventing a buildup of static charge can be as simple as opening a window or using a humidifier to increase the moisture content of the air, making the atmosphere more conductive. Air ionizers can perform the same task.[2]
                            Items that are particularly sensitive to static discharge may be treated with the application of an antistatic agent, which adds a conducting surface layer that ensures any excess charge is evenly distributed. Fabric softeners and dryer sheets used in washing machines and clothes dryers are an example of an antistatic agent used to prevent and remove static cling.[3]
                            Many semiconductor devices used in electronics are particularly sensitive to static discharge. Conductive antistatic bags are commonly used to protect such components. People who work on circuits that contain these devices often ground themselves with a conductive antistatic strap.[4][5]
                            In the industrial settings such as paint or flour plants as well as in hospitals, antistatic safety boots are sometimes used to prevent a buildup of static charge due to contact with the floor. These shoes have soles with good conductivity. Anti-static shoes should not be confused with insulating shoes, which provide exactly the opposite benefit – some protection against serious electric shocks from the mains voltage.[6]
                            Static discharge
                            Main articles: Electrostatic discharge and Corona discharge
                            The spark associated with static electricity is caused by electrostatic discharge, or simply static discharge, as excess charge is neutralized by a flow of charges from or to the surroundings.
                            The feeling of an electric shock is caused by the stimulation of nerves as the neutralizing current flows through the human body. The energy stored as static electricity on an object varies depending on the size of the object and its capacitance, the voltage to which it is charged, and the dielectric constant of the surrounding medium. For modelling the effect of static discharge on sensitive electronic devices, a human being is represented as a capacitor of 100 picofarads, charged to a voltage of 4000 to 35000 volts. When touching an object this energy is discharged in less than a microsecond.[7] While the total energy is small, on the order of millijoules, it can still damage sensitive electronic devices. Larger objects will store more energy, which may be directly hazardous to human contact or which may give a spark that can ignite flammable gas or dust.
                            Lightning
                            Natural static discharge
                            Main article: Lightning
                            Lightning is a dramatic natural example of static discharge. While the details are unclear and remain a subject of debate, the initial charge separation is thought to be associated with contact between ice particles within storm clouds. In general, significant charge accumulations can only persist in regions of low electrical conductivity (very few charges free to move in the surroundings), hence the flow of neutralizing charges often results from neutral atoms and molecules in the air being torn apart to form separate positive and negative charges, which travel in opposite directions as an electric current, neutralizing the original accumulation of charge. The static charge in air typically breaks down in this way at around 10,000 volts per centimeter (10 kV/cm) depending on humidity.[8] The discharge superheats the surrounding air causing the bright flash, and produces a shock wave causing the clicking sound. The lightning bolt is simply a scaled-up version of the sparks seen in more domestic occurrences of static discharge. The flash occurs because the air in the discharge channel is heated to such a high temperature that it emits light by incandescence. The clap of thunder is the result of the shock wave created as the superheated air expands explosively.
                            Electronic components
                            Many semiconductor devices used in electronics are very sensitive to the presence of static electricity and can be damaged by a static discharge. The use of an antistatic strap is mandatory for researchers manipulating nanodevices. Further precautions can be taken by taking off shoes with thick rubber soles and permanently staying with a metallic ground.
                            Static build-up in flowing flammable and ignitable materials
                            Static electricity is a major hazard when refueling aircraft.
                            Discharge of static electricity can create severe hazards in those industries dealing with flammable substances, where a small electrical spark might ignite explosive mixtures.[9]
                            The flowing movement of finely powdered substances or low conductivity fluids in pipes or through mechanical agitation can build up static electricity.[10] The flow of granules of material like sand down a plastic chute can transfer charge, which can be easily measured using a multimeter connected to metal foil lining the chute at intervals, and can be roughly proportional to particulate flow.[11] Dust clouds of finely powdered substances can become combustible or explosive. When there is a static discharge in a dust or vapor cloud, explosions have occurred. Among the major industrial incidents that have occurred are: a grain silo in southwest France, a paint plant in Thailand, a factory making fiberglass moldings in Canada, a storage tank explosion in Glenpool, Oklahoma in 2003, and a portable tank filling operation and a tank farm in Des Moines, Iowa and Valley Center, Kansas in 2007.[12][13][14]
                            The ability of a fluid to retain an electrostatic charge depends on its electrical conductivity. When low conductivity fluids flow through pipelines or are mechanically agitated, contact-induced charge separation called flow electrification occurs.[15][16] Fluids that have low electrical conductivity (below 50 picosiemens per meter), are called accumulators. Fluids having conductivities above 50 pS/m are called non-accumulators. In non-accumulators, charges recombine as fast as they are separated and hence electrostatic charge accumulation is not significant. In the petrochemical industry, 50 pS/m is the recommended minimum value of electrical conductivity for adequate removal of charge from a fluid.
                            Kerosines may have conductivity ranging from less than 1 picosiemens per meter to 20 pS/m. For comparison, deionized water has a conductivity of about 10,000,000 pS/m or 10 µS/m.[17]
                            Transformer oil is part of the electrical insulation system of large power transformers and other electrical apparatus. Re-filling of large apparatus requires precautions against electrostatic charging of the fluid, which may damage sensitive transformer insulation.
                            An important concept for insulating fluids is the static relaxation time. This is similar to the time constant τ (tau) within an RC circuit. For insulating materials, it is the ratio of the static dielectric constant divided by the electrical conductivity of the material. For hydrocarbon fluids, this is sometimes approximated by dividing the number 18 by the electrical conductivity of the fluid. Thus a fluid that has an electrical conductivity of 1 pS/m has an estimated relaxation time of about 18 seconds. The excess charge in a fluid dissipates almost completely after four to five times the relaxation time, or 90 seconds for the fluid in the above example.
                            Charge generation increases at higher fluid velocities and larger pipe diameters, becoming quite significant in pipes 8 inches (200 mm) or larger. Static charge generation in these systems is best controlled by limiting fluid velocity. The British standard BS PD CLC/TR 50404:2003 (formerly BS-5958-Part 2) Code of Practice for Control of Undesirable Static Electricity prescribes pipe flow velocity limits. Because water content has a large impact on the fluids dielectric constant, the recommended velocity for hydrocarbon fluids containing water should be limited to 1 meter per second.
                            Bonding and earthing are the usual ways charge buildup can be prevented. For fluids with electrical conductivity below 10 pS/m, bonding and earthing are not adequate for charge dissipation, and anti-static additives may be required.[citation needed]
                            Fueling operations
                            The flowing movement of flammable liquids like gasoline inside a pipe can build up static electricity. Non-polar liquids such as gasoline, toluene, xylene, diesel, kerosene and light crude oils exhibit significant ability for charge accumulation and charge retention during high velocity flow. Electrostatic discharges can ignite the fuel vapor.[18] When the electrostatic discharge energy is high enough, it can ignite a fuel vapor and air mixture. Different fuels have different flammable limits and require different levels of electrostatic discharge energy to ignite.
                            Electrostatic discharge while fueling with gasoline is a present danger at gas stations.[19] Fires have also been started at airports while refueling aircraft with kerosene. New grounding technologies, the use of conducting materials, and the addition of anti-static additives help to prevent or safely dissipate the buildup of static electricity.
                            The flowing movement of gases in pipes alone creates little, if any, static electricity.[20] It is envisaged that a charge generation mechanism only occurs when solid particles or liquid droplets are carried in the gas stream.
                            In space exploration
                            Due to the extremely low humidity in extraterrestrial environments, very large static charges can accumulate, causing a major hazard for the complex electronics used in space exploration vehicles. Static electricity is thought to be a particular hazard for astronauts on planned missions to the Moon and Mars. Walking over the extremely dry terrain could cause them to accumulate a significant amount of charge; reaching out to open the airlock on their return could cause a large static discharge, potentially damaging sensitive electronics.[21]
                            Ozone cracking
                            Ozone cracking in natural rubber tubing
                            A static discharge in the presence of air or oxygen can create ozone. Ozone can degrade rubber parts. Many elastomers are sensitive to ozone cracking. Exposure to ozone creates deep penetrative cracks in critical components like gaskets and O-rings. Fuel lines are also susceptible to the problem unless preventive action is taken. Preventive measures include adding anti-ozonants to the rubber mix, or using an ozone-resistant elastomer. Fires from cracked fuel lines have been a problem on vehicles, especially in the engine compartments where ozone can be produced by electrical equipment.
                            Energies involved
                            The energy released in a static electricity discharge may vary over a wide range. The energy in joules can be calculated from the capacitance (C) of the object and the static potential V in volts (V) by the formula E = ½CV2.[22] One experimenter estimates the capacitance of the human body as high as 400 picofarads, and a charge of 50,000 volts, discharged e.g. during touching a charged car, creating a spark with energy of 500 millijoules.[23] Another estimate is 100–300 pF and 20,000 volts, producing a maximum energy of 60 mJ.[24] IEC 479-2:1987 states that a discharge with energy greater than 5000 mJ is a direct serious risk to human health. IEC 60065 states that consumer products cannot discharge more than 350 mJ into a person.
                            The maximal potential is limited to about 35–40 kV, due to corona discharge dissipating the charge at higher potentials. Potentials below 3000 volts are not typically detectable by humans. Maximal potential commonly achieved on human body range between 1 and 10 kV, though in optimal conditions as high as 20–25 kV can be reached. Low relative humidity increases the charge buildup; walking 20 feet (6 m) on vinyl floor at 15% relative humidity causes buildup of voltage up to 12 kV, while at 80% humidity the voltage is only 1.5 kV.[25]
                            As little as 0.2 millijoules may present an ignition hazard; such low spark energy is often below the threshold of human visual and auditory perception.
                            Typical ignition energies are:
                            • 0.017 mJ for hydrogen,
                            • 0.2–2 mJ for hydrocarbon vapors,
                            • 1–50 mJ for fine flammable dust,
                            • 40–1000 mJ for coarse flammable dust.
                            The energy needed to damage most electronic devices[specify] is between 2 and 1000 nanojoules.[26]
                            A relatively small energy, often as little as 0.2–2 millijoules, is needed to ignite a flammable mixture of a fuel and air. For the common industrial hydrocarbon gases and solvents, the minimum ignition energy required for ignition of vapor–air mixture is lowest for the vapor concentration roughly in the middle between the lower explosive limit and the upper explosive limit, and rapidly increases as the concentration deviates from this optimum to either side. Aerosols of flammable liquids may be ignited well below their flash point. Generally, liquid aerosols with particle sizes below 10 micrometers behave like vapors, particle sizes above 40 micrometers behave more like flammable dusts. Typical minimal flammable concentrations of aerosols lay between 15 and 50 g/m3. Similarly, presence of foam on the surface of a flammable liquid significantly increases ignitability. Aerosol of flammable dust can be ignited as well, resulting in a dust explosion; the lower explosive limit usually lies between 50 and 1000 g/m3; finer dusts tend to be more explosive and requiring less spark energy to set off. Simultaneous presence of flammable vapors and flammable dust can significantly decrease the ignition energy; a mere 1 vol.% of propane in air can reduce the required ignition energy of dust by 100 times. Higher than normal oxygen content in atmosphere also significantly lowers the ignition energy.[27]
                            There are five types of electrical discharges:
                            • Spark, responsible for the majority of industrial fires and explosions where static electricity is involved. Sparks occur between objects at different electric potentials. Good grounding of all parts of the equipment and precautions against charge buildups on equipment and personnel are used as prevention measures.
                            • Brush discharge occurs from a nonconductive charged surface or highly charged nonconductive liquids. The energy is limited to roughly 4 millijoules. To be hazardous, the voltage involved must be above about 20 kilovolts, the surface polarity must be negative, a flammable atmosphere must be present at the point of discharge, and the discharge energy must be sufficient for ignition. Further, because surfaces have a maximal charge density, an area of at least 100 cm2 has to be involved. This is not considered to be a hazard for dust clouds.
                            • Propagating brush discharge is high in energy and dangerous. Occurs when an insulating surface of up to 8 mm thick (e.g. a teflon or glass lining of a grounded metal pipe or a reactor) is subjected to a large charge buildup between the opposite surfaces, acting as a large-area capacitor.
                            • Cone discharge, also called bulking brush discharge, occurs over surfaces of charged powders with resistivity above 1010 ohms, or also deep through the powder mass. Cone discharges aren't usually observed in dust volumes below 1 m3. The energy involved depends on the grain size of the powder and the charge magnitude, and can reach up to 20 mJ. Larger dust volumes produce higher energies.
                            • Corona discharge, considered non-hazardous.
                            • Static electricity is a major hazard when refueling aircraft.
                              • 1-Dear Professor, I have not yet delivered. 2- the device also works without a housing and at a distance of 50 cm from the battery. 3- each person has different principles and requirements ... I already wrote to you that you should RESPECT the people around YOU, wherever it is, on the forum or where YOU eat and go to t ... Respecting YOU friend.
