Delta Pulse
  • Originally posted by Jose View Post
    It is likely to be false or damaged due to improper installation of VD4.
    i wrote many times do not use 1m coil in the room. he did ignore off all my suggestions.
    deplorable consequences. he does not hear nothing. he wants go just his way despite on all warnings.
    • Unless he lives in a wooden hut
      • very bad assembly. lousy soldering. workmanship zero.
        • HI CHUUBABA....YOUR C1 CAPACITOR IS MISSING!
          • Thank you TufaN and Tifred for your attention to the board.
            C1is soldered on copper side ( back side of the board)
            • Chuubaba, did you put scope probe to leg 6 of the LF356? What did you see?
              Stop buying chips online, most are fake except from reputable supplier. You must learn to salvage these common chips from old equipment tossed out such as old Graphic equalizers, mixers, preamps and old car amplifiers and other type of audio equipment contain a bunch of these very common op-amps. Dig around the town!
              • dbanner I will do the with test as advised by you on next weekend.
                Today i wound a 280mm diameter coil with 0.25mm wire. Inductance is 486 uH but resistance is 9.6R (including the connecting cable and connector) which i am sure is very very high. How i can adjust such high resistance coil with the DP ? (i will change other components for small coil as written in BOM).
                Thank you
                • Originally posted by chuubaba View Post
                  Thank you
                  0.25 mm for a 280 mm coil. For 280 mm coil, you should use 0.50 or 0. 60 mm wire.
                  • I will make a new 28cm coil as you said.
                    Looks like your board has lost some tracks. Mine too. I am going to order new boards from China but got no clue on specifications for durable tracks.
                    • 0.25 mm for a 280 mm coil. For 280 mm coil, you should use 0.50 or 0. 60 mm wire.
                      Hi TufaN!
                      Thanks for your tests, perfomance are realy realy not bad! I see distance 40+ cm to coin.
                      What about current consumtion, how much mA your DP takes from battery?
                        This Click image for larger version
                        I
                        • Chub, that is a very sharp and clear image you have shown, I've never seen better. The scope trace is very nicely focused and the camera is high resolution, congratulations.
                          I can barely make out what's going on.
                          • Hi
                            How much is voltage at pin 6 of lf357??
                            • on pin 6 - this is OUTPUT of operational amplifier (opamp, op amp, op-amp) - is impulse signal,
                              it is 'cutted 'delta' pulse on its top' but inverted (cutted by two diodes VD3 and VD4). the opamp is in invertor circuit usage here.
                              so you see via your oscilloscope the 'low part' of whole 'delta' pulse on coil.
                              no DC signal you would be like to measure by a tester. without mos-fet on output of the opamp is GND (ground, zero) level, in relation to output of DA4:A.
                              • Do you have diagram of T1(pin 6 of lf 357)??
