Delta Pulse
  • Does anyone have lcd kit for deltapulse?
    I need an led kit for my deltapulse
    • I've had it! I tried another battery in the DP. Something is broken inside. There is no virtual ground. E +, E-values ​​are bad. E + 2V, -E = -10.45V. The diodes are good. TL072 reversed. She began to heat up in the IRF. Because there is no pulsation. I give up the fight ... Or not? :-)
      Something must select a stable solution to +5 and-5V to develop, is not it?
      • Originally posted by szucs_g View Post
        The tl072 burned out and irf840 to the boil. On Monday go to the grocery store. I buy plenty of them. Apparently consumables. :-)
          anyone write me in PM.
          I did refuse 7909 use. but you can try it... I placed 7909 instead diodes VD8 and VD9, on their places (the diodes was been desoldered). photos I did not do.
          my mod now... converter on LM2577-ADJ... if it is working good in Milelab so I think it will be working good in DP too
          Hi KT315 ,
          what's about LM2577-ADJ... are you trying to get stability with delta pulse or not yet ?
          if it is good please put how to connecting and many thanks
          • Originally posted by raff33 View Post
            Hi KT315 ,
            what's about LM2577-ADJ... are you trying to get stability with ?
            hi. I still wait STTH1210D be arrived... can say nothing now before it will be installed.
            see you later
              see you later
              ok good luck
              • Ne556 was swapped in, but he did not want to vibrate. Capacitors, resistors ok, the diodes as well. The first half of the ic wibrating well, but not the 9-foot. I noticed that the potentiometer (noise) soldered was broken. That was the trouble. :-)
                I found the rotary switch. 4 x 3-position. It would be worthwhile to redesign PCB and all three rolls to make it suitable solution. The switch could switch to the lowest 28 cm, 40 cm and 100 cm search head proper configuration. Good idea? The answers found that the frequency of dumping resistor should change. This has come with a small roll, the transistor T2 collector off and a 1.5 nF capacitor 1 nF to replace. If I missed something please write. So would three and four parameters to change rolls. This switch (rotary switch) could be solved.
                http://www.hestore.hu/files/lorlin.pdf
                Bye! Gabor
                • szucs_g
                  For coils of 28 to 45 cm, I use the same frequency (400 to 550 Hz).
                  Roll 1X1 meters, I use 150 to 170 Hz
                  Place a simple switch C1, to add capacity in parallel to achieve the rate of 150 Hz.
                  Increasing the power (power control, and measure the total consumption of the DP, in alrrededor 180 to 200 mA).
                  Use different resistors inside each coil to compensate for the differences.
                  greetings, Jose
                  • Thank You!
                    28 cm coil with 550 Hz and 40 with 400?
                    With capacity can I modified the frequencies easy. (take in parallel :-) )
                    May I set up power with a fixed resistor? To 180 or 200 mA.
                    Witch dumping resistor must I use to 28 cm (550 Hz), 40 cm (400 Hz) and 1m (150 Hz) coil's? Can I measured it with multimeter or experiment, this does not warm the fet?
                    • #1402
                      "plz help about this problem :
                      http://www.4shared.com/video/giM6Cxn...2012_001_.html "
                      What kind of house do you live? If the concrete floor below and there is lots of iron, the DP is not able to calm down. Anyway, nice carpets. Easterners?
                      • Coils from 28 to 45 cm.
                        Use the same frequency coils 28 and 40 cm, the value determined experimentally for better performance (from 400 to 550 Hz).
                        Measure the frequency with a tester.
                        Set the pulse width (power), 100 to 150 usec. Use oscilloscope.
                        If no oscilloscope, adjust the power for a total consumption of DP between 130 and 150 mA.
                        1x1 meter coil
                        Use a frequency of 150 Hz or so. Measure the frequency with a tester, determine the value of CX experimentally.
                        Set the pulse width of 200 usec. Use oscilloscope, or measure the total current of MD at 180 to 200 mA.
                        If you respect the power values ​​mentioned, the FET should not be heated.
                        Place a higher value than normal for the damping resistance in the PCB.
                        Set this value with a resistor installed in each coil. Determine experimentally the value for best performance in each case.
                        see diagram
                        Greetings Jose
                        • sniffer xr71
                          Hello again. My delta dont work continues. Here's what I found.Coil does not react to metal. pin 5 ic 556 8.65v---pin 9 ic556 11.9v pin 2 ic 357 7.85v---pin 6 ic357 10.55v pin 6 ic 4538 9.80v pin 1 ic tl062 10.28v---pin 7 tl062 9.30v pin 2 ic 555 5,00v ---pin 5 ic 555 6.29v--- pin 7 ic555 4,95 IRF840 gate 8,65v-drain 1,75v-source 0,06v - sound work, work potentiometers, diodes are not broken, I really do not know what to do more. I know what I will do. I smash my Delta and go fishing. thanks
                          • Originally posted by dimovnis View Post
                            be more accurate. your montage on PCB back side seems very vulgar. do not use unisolated wire on the side because you can elementary short the circuit.
                            • sniffer xr71
                              My coil is 30 cm - 3.6om
                              R5 is 1 K
                              R6 is 680R
                              When I turn on the delta for 5 min coil is heated a little, and not reacting to the metal
                              I know it looks very, very vulgar, but all I checked the no short-circuit
                              Sorry you do not know But I hope he will learn
                              • hello
                                i think delta pulse version here is not idiot prooven (but that is what i need)
                                too much thinks that can go wrong
                                so i will order a commercial kit next month, copy it and then give it to here
                                that could solve my own problems and also all the troubles
                                that the 80% to them i belong here have
                                we need a version that everyone can build without crushing his diodes or fets or something else on first start and when you see something is wrong the hole unit crushes
                                (i had connect my batteries 2 seconds to long until i smell the plastic but from where) i thing it was irf740
                                regards bernd
