What pulse metal detector is most friendly to mineralized soil without a ground balance? Is it pulsar, lorentz 5, xr7, xr71, tl12000, polones, or modified felezjoo?
best pulse
I suspect that in order to use a 1-2 meter coil you need a circuit that runs in static mode. And I also suspect that increasing the gain/sensitivity will make things worse, not better. Other than that, probably most basic PI circuits can be made to work, and I have no idea which would be "best."
I need to run pi on red clay. The most likely outcome is to work close to the lowest sensitivity. So a precision potentiometer is needed to reach the critical point of sensitivity and reach the best range. I've seen a video of an expert who modded the fpi and ran it on clay, but he wouldn't tell me how. He gave me a lot of useful information.
Hi ZOUjiarui,
you say, you need to run a PI detector on red clay soil. What kind of detector have you tried on red clay soil? And how has the detector behave?
And can you give us the link to the video you mention in post #5. What additional information have you got from the person? Maybe, if you share the
information people can help you to figure out what kind of modification he has done to the detector.
[COLOR=inherit !important]
[/COLOR]
[/COLOR]
Hi ZOUjiarui,
I had a quick look at the Felezjoo PI detector schematic which I found on the Internet. The detector just has an analogue front-end circuit. The remaining circuit is for a digital detector. That means, all of the modification is most likely made within the software. If the source code is not available, you cannot do much at all.
What detector circuit have you build so far? Maybe you can modify one of them to run on red soil as well.
