Gpx 4500
  • Gpx 4500
    Hello everyone on the forum there are more professionals for Minelab gpx, I hope someone will help with the problem that appeared on the gpx4500​.The detector has blocked in cancel mode,​ the switch is fine your opinion what is the problem​ ?
    It actually only works with a mono coil, it cannot be switched to work with a dd coil​ !
      Multiplexer 74hc4053. It changes the configuration of the outputs of the input amplifiers for mono and 2d. The most likely cause of the problem
        Thats what happen with me . But he bugg work after resset fectory https://www.geotech1.com/forums/foru...-problem/page3
