Proscan PI Project is alive again!
  • Proscan PI Project is alive again!
    Just mailed off to Mouser for the parts for the Proscan PI unit. I built the GoldPic3 and have shelved it as it didn't work right off and with the ideas I want to try the Proscan unit is much easier to modify since it doesn't have a uP.
    First thing I want to build is a Time Gain Amp and the second thing is a 8-tap delay line to add the pulses over and over with each pulse, thereby giving a better S/N. Carl, I think you'll remember this if you looked over RADAR signal processing techniques, it's called "Video Integration". I would have a variable opamp delay ckt. to set the point at which I want to begin to add the return pulse. I think there's lot's of work to be done in this area and of course as mentioned on the PI forum, I am very interested in using a Spectrum Analyzer as you get alot more resolution than looking in the Time Domain. I've also bought a couple 12V latern Batts. from Radio Shack and 4-4' copper ground rods to put a DC potential in the earth to experiment with enhancing my VLF detector. I think this is what Compass Electronics is doing with their Depth Doubler for $495. I've only done a quick test in the backyard and inconclusive with the nugget I placed in the ground, but sure got alot of signals that showed up when the 24VDC potential was applied to the ground. I'm going out to the El Paso Mtns. tomorrow in the Mojave Desert and will try the DC setup again and see if I find any nuggets.
    Randy Seden-Simi Valley, CA.
    Re: Proscan PI Project is alive again!
    Randy: es muy facil cambiar el micro por un circuito simple tipo CD 4011 del proscan. Yo modifique el Proscan colocando un lm318 en vez que el ua709, cambie el transistor por el MOSFET 720 y agreque un preset para cambiar el delay y el sample del pulso de muestra y trabaja perfectamente, cualquier cosa comunicate conmigo y te mando el circuito modificado
    Carlos
      Carlos, Please use ENGLISH , no comprende espaniol n/t
      n/t
        Randy, sorry, You can use the traslator for read my message.
          Randy,
          What do you mean it doesn't work!! Just where do you think the error(s) lie?? If you build something from a "certified" board, then surely the error is with you. You give "tinkerers" a bad name!! If you want some help - then ask.
          Projects that get shelved just give me pains.
          You will learn and appreciate far more if you stick with a project and realise it. Though you are far away send it to me if you're stuffed. Don't go chasing clouds.
          g.
            Graeme
            Your making too many assumptions considering you don't even know me. I realized half way thru the project that I wouldn't be able to make the experiments that I wanted to with the GoldPic as it's run by a uP and burned in at that, but decided to go ahead and finish anyway. What got me disgusted with the board was having to put in 13 or so jumpers! Trevor is obviously not a circuit board designer, but a very good electronic designer/programmer. It would behoove him to pay someone to redo the board and fix it.
            I have alot of experiments lined up and I'm not going to throw alot of my time after something that I can't do them with! I don't know about you, but I'm smart enough to realize when something isn't going to get me where I want to go, to set it aside for later when my goal has been achieved.
            I've already started building the Induced Polariztion transmitter. That's the cutting edge in Geophysical Exploration and have got most of the receiver completed. So in the future Graeme, please e-mail me rather than emabarass me in front of other experimenters. You can cut me a new one at: r.seden@worldnet.att.net anytime!
            Randy Seden-Simi Valley,CA
              Had a radar class in grad school, haven't touched it since! I'll have to pull out the books and review the technique.
              I don't remember, do you have an o-scope? What's not working with the Goldpic? I'll probably build this just for fun as my own design efforts have been dragging lately, no reference circuit to compare with. I've not seen the PCB but I guess from your comments it is single-sided, hence the jumpers. I just got a new schematic/PCB package (CircuitMaker 2000) so maybe I will re-layout the board.
              Depth-doubler: I think Garrett also once sold one of these, withdrew it because it didn't work. I'm not so sure it's straight DC. If I had the extra cash I would buy every one of these wonder devices just to rip them apart and post the schematics, if there is anything to them. I know some of this stuff is just a scam.
                Garrett Still makes the device and calls it the "Treasure Hound". I talk often with a guy that uses one extensively and swears by it. I happen to know that he's found several big caches with it(very deep) --one was in a hidden cave. He picked it up at about 8 feet.
                He earns a real good living with the "depth doubler".
                Let me know how the project works. I'm an electronics idiot. Electricity shocks--that's all I know. I'm planning to actually do some of these projects.
                See ya
