Deepers Detector
  • hello did you receive my MFC mail?
    • Can you give x5 measurement points, voltage values frequency and so on?
      • Thanks (MFC ) MY Regards.
        • Yes i recive thank you
          • hi Maikel, what is the critical setting for mineral soil and which parts will change?
            • For example, I don't want him to see the old brick.
              • you also did not respond to my e-mail.
                • In mineralized grounds you must adecuate the sensi, reduce sensi, if not a you get signal from soil. The problem is that deepers dont have ground balance included, it have only a main same delay.
                  • Hi (MFC) ARE DEEPER 10DD works well . And the (varestor ) composant that in deeper 10dd what is the number code.
                    • Help i cant found 430pf what can i remplaced
                      • Hi
                        470p
                        Varestor mf075 .4ohm
                        • Thanks salare12 my regards.
                          • Originally posted by sbalio1 View Post
                            You can parallel two caps to sum to 430pF. Like a 100pF and a 330pF
                            • hi frinds i cant find varistor 075 . the equivalent please
                              • this is not varistor. set a fuse or jumper. or https://www.ebay.com/sch/i.html?_fro...LH_TitleDesc=0
