Fisher CZ 6A coil connector wiring
  • Fisher CZ 6A coil connector wiring
    Cannot locate a diagram for the CZ 6A coil connector on the back of the housing and also for the connector on the coil cable. If someone can share that it would be much appreciated.
    Frank
    What exact precise information do you need Frank Perhaps I can supply some information.
    Tx coil is 2.4 uH, Rx is 9.6 to 11.6 uH.
    I know the wiring color for the Tx but not the Rx. Green of coil connects to white wire of connector, is the plus side of the wiring.
    Shield is the ground side, connects to green wire of connector.
    Knowing that, you should be able to guess the color of the wires on the Rx side.
    On Rx coil, do not have the color of the wires, but the positive side of Rx coil goes to a C11, 0.1 uF, then to R6, 48 ohm. On the negative side, you should hve the remaindner of thewiring material.
    Melbeta
      A fellow sent me the info i needed Jerry and thank you for the offer. I did not have the specs you mentioned and those are always welcome and i wrote those down in my small black book i use for detector information. Have a great day.
