Hi Admin: This forum doesn't have a search function to find the topic. For example, I want to search for the idx device name, but it doesn't work. Please include the search option.Thanks.
This forums have not serch subject
I think I can see what Perzo is doing differently.
If you select the Forums tab and then use the Search box in the top right of the screen, "IDX" produces 100 results.
Even if you select the New Topics tab, "IDX" still produces 100 results.
However, if you use the Search Result Keyword box (on the left), and search for "IDX", you get zero results.
It appears the the top right-hand box searches the whole forum, but the left-hand box only searches the current search results.
It's a bit confusing.
The main search box is in the upper-right of the forum. If you are at the top of the forum then you can narrow your search to the forums only, which omits results from the "Articles" side (right now there is not much there).
If you push into a forum (say, the Tech forum), then the search allows you to narrow your results to just the Tech forum:
If you then push into a particular thread you will see a new search box in the toolbar. This allows you to search within that thread. For example, the "IDX-PRO+VDI" thread has 4,160 posts in it. Suppose you recall someone said something about the XLT in that thread. When you do a search on "XLT" you get only the posts containing XLT, and you now see 16 posts instead of 4,160 :
It appears that all these search methods are limited to 100 results. I don't know if that's a problem or a practical limit of what a person can even consider.
