Zismes New Homebrew Metal Detector on http://oldradiobuilder.com/MDET.html is a little improvement!!! Doesnt the capacitors reduce the small voltages the coil detects, Is it better to use a second coil for Rx instead of the capacitors...is it better to use single supply instead of dual supply for Opamps!!
Zisme Detector
Originally posted by sharky View PostZismes New Homebrew Metal Detector on http://oldradiobuilder.com/MDET.html is a little improvement!!! Doesnt the capacitors reduce the small voltages the coil detects, Is it better to use a second coil for Rx instead of the capacitors...is it better to use single supply instead of dual supply for Opamps!!
