“S”- tone discriminate metal detector.
  • #31
    Resistor R 24 replacement only for first variant.
    This is second ,BEST VARIANT schematic-free of mistake, work perfect.
    Sascho
    • #32
      What is the function of "r2", "r3" and "r4"?
      SASCHO please explain them.
      Best regards.
      • #33
        r1-referent phase
        r2-ic C pin1- offset amplifier toward +8v adjust.
        r3-icC pin7- offset amplifier 0v=u/2
        r4-audio frequency
        Sascho
        • #34
          R24-Motion speed.
          sascho/bg
          • #35
            With DD coil this schematic work also very well .
            • #36
              Sasho this schematic looks pretty interesting. I am very ready to draw pcb for it and make device. Can you help here and explain those few asteriks over some components?
              Also one more question; R49 100K is "Tune", right? Tune what?
              Further.. are the TL062's really best choice there?
              I will start drawing pcb these days. To many other things to do, so i will go slow on this.
              Regards!
              P.S.
              Sasho where are You from? I know only that you are from Bulgaria, but which place? I would like to email you some other questions, can you send me your email address?
              ivconic@gmail.com
              • #37
                Not tested
Name:	Sasho S connexions.JPG
                Sascho S1.zip
                • #38
                  Thanks Patrick!
                  Nice pcb.
                  • #39
                    R49 100K IS Tune.
                    R24=150k-big depth.
                    Tl062-no problem.
                    S-coplanar coil-
                    http://bgcenter.net/users/copl..JPG
                    • #40
                      Originally posted by Sascho-bg View Post
                      R49 100K IS Tune.
                      R24=150k-big depth.
                      Tl062-no problem.
                      S-coplanar coil-
                      Hi to all.
                      • #41
                        Hi Sascho
                        Please explain about DD coil.
                        Best regards.
                        • #42
                          DD coil
                          26cm diameter
                          L1=L2=100 turns.
                          • #43
                            Thank you Sascho, and what is wire diameter ?
                            • #44
                              0.31mm
                              • #45
                                Sascho ,
                                I am busy constructing your best VLF detector .( with two 4007 ) .
                                I built full resonance vlf detector many years ago .it is based on elector
                                Magazine VLF detector and modified by me. I decided again experiment
                                full resonance detector . I need VLF dipper detector.
                                Also your “S “detector interesting .
