this is a redrawing from a very blur copy of the Baraccuda PI. If you are interested you can cross check the diagram and post the errors in this forum. Please read the note in the schematic.
thanks for your kind support. Now it's a difficult task to adopt (some of) your component values. Because the board you mention is an older version of the Barracuda. I'm pretty sure that yours is an earlier version than Revision "D" because of Q1 (TIP127).
Why? If I would be the designer I would try first a PNP Darlington and in a redesign I would change it to a Power MosFet. I wouldn't do it the other way round. Ha Ha... and another thing confuse me where is the 7660? In the drawing is a 555 timer. Or am I wrong?
The input pins of U4a are correct drawn according the blur copy.
Is it in the original copy wrong?
1. Q1: You have used IRF9410 - but it is an N-channel MOSFET. It should be an irf9530 (a P-channel one).
2. 7660: Yes, there is a 555 in the drawing - but this is an error. It will never work. Perhaps in a very early version a 555-based voltage inverter was used and somebody forgot to change the chip in the schematic. This is an almost correctly wired 7660 switched-capacitor voltage converter.
3. U4a: Next evident error in the "original". You should expect more bugs.
Thanks for your support. I'll wait till the weekend and collect error messages. Maybe more are coming. On Monday I'll post an update of the schematic with all collected errors.
