Commercial schematic here:
  • Commercial schematic here:
    White's 6000 Di Pro schematic (7 .JPG files) here:
    http://mtdetect.narod.ru/support.htm
    Re: Commercial schematic hereincomplete)
    I downloaded those files and 2 of the files are duplicates. So it looks like probably at least 2 of the files are missing. I'm not absolutely sure but there seem to be a lot of loose ends with no place to connect on the other sheets.
    Russ_NY
      Two links point to the same images (Pro1 points to Pro3). You can pull up Pro3, then manually change the URL to Pro1, and get it that way.
        Compete schematic + description here....
        Hi guys,
        here is a """very hot""" link to the complete schematics, block diagrams, description of the White 6000 and much more... Check it out....it's not far away (the link)...... actually "next door" at Geotech. By the way there is much more good stuff to see....
        Chris
        White 6000
