PIM-2 Digital Metal Detector Project
  • #76
    Originally posted by Jose View Post
    Hello Detecto
    Can you please tell me what is the difference between software V0, 5 that you use, and the full version.
    Where are the archives of PIM-02.
    Any other information that is useful, because I am interested in the construction of this MD.
    Thank you, a cordial greeting.
    Jose
    Hi Jose, generaly v02 don't have discrimination (if i remember)
    v05 have discrimination good one, and this is last published software for now, of course it is demo software, demo and full version don't have diferences except limit for 500 on of switching.
    elbombaci also made software V06, i don't know anything abouth that versionn, you can contat him for details.
    Detecto
    • #77
      Generally PIM-2 is worth to be made, it's one werry good detector, and i notice only one problem, if small target (coins) don't lie perfectly horizontal (referenced to coil), PIM-2 can't detect it at all.
      I don't know is this jus problem in my PIM-2 or major problem of this detector.
      Detecto
      • #78
        Thanks Detecto
        Perhaps the design of the detector does not provide a low delay. Could be the cause of the poor sensitivity to small coins or gold ring.
        • #79
          Detecto
          This is in my opinion typical of PI coils. Coins and rings go deeper when held flat or horizontal.
          If you turn them on edge the depth drops dramatically.
          If you cannot detect a coin on it's edge you need a smaller coil, or a very well made bigger one.
          You won't lose as much depth as you think with a smaller coil, because the valuable items can be detected and detected deeper.
          Cool project.
          • #80
            Cool project.
            Yes i agree wiht you.
            Detecto
            • #81
              Hi to all.
              I have made a pinpointer for my PIM-2 shortly before.
              http://i1226.photobucket.com/albums/...s/DSC00234.jpg
              http://i1226.photobucket.com/albums/...s/DSC00232.jpg
              http://i1226.photobucket.com/albums/...s/DSC00235.jpg
              And video:
              http://www.youtube.com/watch?v=2oKoW5NMpSs
              I used 330uH mini inductor.
              Best regards.
              • #82
                Hi to all
                ------Please comment ----------
                -With Notice how to Change Atmega8---->pic 16f877a.
                -The same Way display screen = The same Way HEX FILE
                -The same PCB.
                http://www.youtube.com/watch?v=PxhIhHz7eAU
                best time
                j.
                • #83
                  Hello, is used as a base foundation of Pim 2 are not identical, but see for yourself that discrimination works much better than Pim 2, this machine is a crazy-star 1 . thank you
                  • #84
                    hello elbombaci
                    I have made 2 coils 30 cm of diameter but I have a problem
                    when i measure the first coil I find 4.5 ohm
                    and the second (CAT5E) is 8 ohm
                    so the question .
                    Which coil is correct to use?
                    thanks a lot
                    • #85
                      Hi volcano
                      use the coil that has30~35cm cat5 3x8 = 24tu.
                      best time
                      j.
                      • #86
                        Hi sinko1
                        I see that 2 works same!!!!!
                        best time
                        j.
                        • #87
                          Originally posted by jap View Post
                          Hi sinko1
                          best time
                          j.
                          Hi, display vizualization is same, but crazy star is more stable and selections is very good
                          • #88
                            Hi sinko1
                            From your point of view the change Atmega8---->pic 16f877a. an effect.
                            best time
                            j.
                            • #89
                              Hi volcano
                              best time
                              j.
                              thank you jap
                              I made 30cm coil with CAT5E 3X8 ( so 24 tur)
                              But the problem is
                              When I measure the the coil I find 8
                              volcano = elmahboule
                              • #90
                                Hi volcano
                                -By Digital set Measures 3 ohm.
                                -Try to calibrate the device before measuring .the short between two measurements lead will give first value ​​of wire resistance and measure the value then subtract the first value,give coil resistance.
                                best time
                                j.
