Surf PI Pro
  • I have placed trimmer on both of my surf pi pro in place of 3k3
    it is working with resistor but trimmer gives you way of adjusting - more depth - more consumption ...
    • ?Surf long Board arberg gold ring size 2.5 cm sensitip in the air between the strong voice in 17 cm 24 cm voice coil diameter 20 cm start weak. 25 Coil wire 0, 5 mm but less than 10 cm silver ring.
      • I think best results are with 21 cm coil 25 turns 0,4 mm copper enamelled wire
        can you measure you coil with LRC meter ?
        what is resistance of coil ?
        what is inductance of your coil ?
        • ?The wire that I bought I can't wear gauge coil wire count only enamel copper colored jumper IRF9640 0,5 330omh 2watt and I do not understand the induktasi coil I but less sensitive silver ring sdesic I do not understand about electronics but merely a hobby and I'm also not the engineer is capable of if I exsperimen coil can detect gold ring in 30 cm what do I do
          • ?I use 12volt dc 3, 5am
            • You should try working on batteries or power cell which is not AC-DC adapter... some disturbance comes from AC power
              try working on 8 x 1.5V batteries or 12V lead sealed battery 1.2Ah or better
              try different AC adapter if you can
              If you have one plain 1,5cm coin you should try that so we can compare
              I have 1 EURO coin on 15 cm ... other coin can be found on 20 cm ... composition and size of coins are different
              • ?I've tried to use the coins made of allumunium less sensitive with silver ring I wear a motorcycle battery voltage 3, 5am do not use an adapter from ac to dc
                • you can look for my post here
                  http://www.geotech1.com/forums/showt...497#post170497
                  and follow steps by Jose and others
                  read fist and then try something...
                  you can replace R2 with trimmer 5k for beginning
                  use more than 3k3 and you will gain more depth but it can overheat IRF and take more power from battery
                  • ?Ok I'll try it later thanks for the info
                    • As I mentioned before I have problem with my surf pi pro
                      -5 V is not there when all ICs are in place
                      -5V is there when I pop out all ICs
                      I returned all IC same thing, so I returned all but LM358
                      there is -5V ... replaced with new but same thing happens
                      no -5V on 7660 or on other places
                      Any ideas ?
                      I had problems with one missing capacitor
                      220nF capacitor was missing and I used one older (224K 250V type) and one new 63V
                      • You are saying that with all IC's in the board there is no -5v
                        but take them out and the -5v returns.
                        I had a similar fault it was a faulty 5v regulator
                        it could not handle the load with all IC's plugged in , what voltage do you have on the input to 7660
                        with all IC's in the PCB ?
                          7660 is working on other surf pi pro ... changed with new one and same thing happens
                          with all ICs in place 7660 gets its +5V
                          on pin 5 there is +0,5V
                          located problem close to LM358 ...
                          when I take out that IC -5V returns
                          something faulty ... resistor or capacitor maybe...
                          • Can anyone help with this problem?
                            Where can I find oscilloscope test points?
                            Graphs for surf pi pro ?
                            • You may try here http://www.njuskalo.hr/index.php?ctl...nce&sort=cheap
                              It worked for me.
                              No way you can do any meaningful measurements in PI without a real oscilloscope.
                              • last night I desoldered everything associated with LM358 on PCB and it still has that effect on -5V
                                socket gets +5V and -5V... and when I place IC in socket I loose -5V
                                must try that IC on other device I have again
                                I am on the way to get one channel oscilloscope which has no probes for testing
