Echo example
  • Echo example
    I am looking for a recorded echo(s) of a sidescan to use as test signal.
    It will make testing much easier.
    Regards, Jan
    Re: Echo example
    Hi
    What kind of specs do you have in mind ?
    A number of lines 8 bit x 512 samples/ channels
    is what I have.
    Sture
      Re: Echo example
      Sture,
      I was thinking about signal coming from the transducer.
      I will be needing something to test my echo processing.
      The echo you have will be very usefull.
      I suppose its not "raw" echo but already an echo processed by a DSP card. (I.e. DAC output)
      I could use this data to test if I will use a DSP card or see if the PIC is powerful enough to do the signal processing also.
      (Love these PIC's.... can change whole setup by just reprogramming a few pins... hehe)
      Perhaps you could send file to Carl, so he can put it on the forum's Project Files folder.
      Regards, Jan
        Re: Echo example
        Sure..
        I will search for the CD. By the way I don't process
        my data with DSP, only a minor filtering.
        Sture
          Re: Echo example
          Sture,
          Glad to hear that.... means my filter can be simple also.
          Regards, Jan
            Re: Echo example
            My filtering is bandpass in the towfish as showed
            in the schematics. One more bandpass in the
            upside amplifier and a anti-alias filter before
            the ADC, a RC lowpass filter.
            Sture
