are barium titanate hazardous?
  • are barium titanate hazardous?
    I will cut barium titanate piezodiscs to suitable bars
    by grinding.Does anyone knows are grinding dust or slurry hazardous for health?
    Re: are barium titanate hazardous?
    Yes. Any type of dust can be hazardous to your health, but especially dusts with heavy metals such as barium or led, even in the oxidized form of titanate. Wet grinding techniques are a lot better than dry techniques, but even so, a fabric mask is recommended. If you're been exposed to lots of dust, or plan to grind the piezo discs on a regular basis, my sources recommend getting a heavy metal test as a baseline and then get tested every year. If you don't grind the stuff very often and take measures to reduce the amount of dust, a mask may be sufficient.
    I'll see if I can find an MSDS on barium titanate for you.
