Autonomous underwater navigation using imaging sonars
  • Autonomous underwater navigation using imaging sonars
    hey ! can anyone help me in this regard by providing me with links related to above topic?
    Any data on above will be most useful to me ....
    Imaging Sonar
    Check out the following link
    http://www.oceantools.ltd.uk/pdf/sonar.pdf
    [email protected]
      Typically done with Doppler Velocity Logs, such as RDI sells.
      www.rdinstruments.com
      Higher end systems will use gyros as well (accuracy goes up along with cost).
      If you want to use a global coordinate system you also need a good initial fix. This means good WAAS/DGPS/GPS.
      There are also underwater short/long baseline systems - kinda work like RDFs + RF beacons in nautical nav.
        Imagenex 881A imager sonar
        http://www.imagenex.com/Products/881...a_imaging.html
