What model of SSS would be suitable
  • What model of SSS would be suitable
    Hello folks,
    I'm looking for SSS which could imagine-detect 10cm size objects (trash). What model could do it and what technics are used for such purpose.
    Any recomendations are very appriciated
    thanks,
    Rob
    Re: What model of SSS would be suitable
    Rob,
    Edgetech has Side scan systems that can resolve objects smaller than 10cm.( see below) The Portable 4100 system comes with a target logging program that will calculate the position of the objects imaged with the sonar.
    272TD Towfish - Beamwidths and Target Resolution @ 100m.
    The 272 One Way Beamwidths are
    390Khz = .47degrees
    105Khz = 1.8 degrees
    and the Two Way Beamwidths are
    390Khz = .38 degrees
    105Khz = 1.44 degrees
    The resolving ability of a side scan sonar is dependant primarily on its along track beamwidth and
    receiver bandwidth. To provide a definition for resolving power we state:
    Definitions:
    Resolution (in a sonar/radar system context) is a measure of the ability of the system to
    distinguish between two closely separated targets. High resolution systems can "resolve"
    two close targets better than one with poor resolution. This ability is often measured or
    quoted in meters.
    Thus:
    The resolution of a sonar is its ability to determine the presence of two small objects
    separated by a distance X. If the resolution of the sonar is greater than X, the 2 targets
    will appear as one in the sonar image. If the resolution is X or less the target should be
    resolved into 2 distinct targets in the image.
    For this purpose we use the following rule to determine if the targets will be resolved.
    "The resolution of the sonar is twice the two way 3 dB beamwidth."
    390Khz
    At 100 m, the along track, two way beamwidth is 0.66m. Using the above definitions and
    reasoning the resolution of the 272 HF channel is 1.3 m
    105Khz
    2 way Beamwidth in meters = 2.52m, so the resolution is 5.0 m.
    Pings on Target
    The above discussion does not include the effects of sampling the image. When the image is
    sampled, this may further degrade the ability to resolve the 2 targets.
    The Sampling of the image in the along track dimension is determined by the Ping rate / Tow
    speed relationship.
    Experimental evidence shows that to sample a dataset acquired with a resolution of Y meters
    without loss of resolving ability, the sample spacing should be 0.5 x Y or less. Note this is the
    minimum limit, and experience shows that higher density samplings significantly increase target
    detection.
    If you need more information contact me directly.
    Rob morris
    Edgetech Customer Service
      Rob,
      So what's the range resolution of the 272?
      Mark
        Mark,,
        Due to beam spreading the along track resolution depends on the range. The along track resolution of the 272 at 100m is about 1.3m., .66m at 50m. The accross track resolution is
