Fisher FX 3 magnetometer
  • Fisher FX 3 magnetometer
    Hi
    I have a Fisher FX 3 mag that i will like to ask if possible to add a mod to work also has a no movement detector.
    Nelson
    Originally posted by nelson View Post
    Hi
    Nelson
    Hello Nelson,
    Do you have a schematic from it ...and some photo's from the inside ?
    Regards.
    Ap
      Hi ApBerg.
      Nop i dont have the schematic and photos, but i can get them soon
      Nelson
      Originally posted by ApBerg View Post
      Hello Nelson,
      Regards.
      Ap
        The Fisher FX 3 mag cannot be used without motion. It is a induction magnetometer.
        No matter what you do to the circuit it reguires motion.
        You need a fluxgate magnetometer like the Schonstedt 52b
          Hi
          Nelson
          The FX3 is a differential induction magnetometer. It comprises two induction coils wired in series for gradiometric operation, going into a high gain DC amp, thence to a precision full wave rectifier, the output of which drives a VCO.
          If you want it produce a static (no motion required) response, you'll need to add an integrator to the output of the DC amp, including a tweaker pot to adjust out offset-induced drift, and a momentary switch to zero the integrator. With an integrator you may get a lot more sensitivity in bench testing but no matter how hard you try to eliminate integrator drift it will still be a limiting factor.
          --Dave J.
            Hello Dave,
            Can the FX3 pick up static magnetic fields without motion?
            Best regards
              No, the sensors are induction coils.
              --Dave J.
