Just getting head round things..
Is it fair that the geb channel does...
1)Gives a 'quiet' detector when set right - as ground signals are approximately integrated to zero.
2)The phase shift on the GEB gating is set away from target alloys while doing GEB things - So does not contribute as much target signal level as main Disc Channel.
3)Threshold level is set to just above GEB channel level at final comparator.
As, the Disc chan gating, is aligned with target alloy phases - the Disc chan picks up more target signal than GEB?
The Disc Chan gets some ground signal on it?
Loosely speaking then, the GEB chan does not contribute valuable Target signal power - it is used for a threshold for setting the beep off?
If you made a machine without a GEB Ch and you could tolerate the ground signal on the Disc Chan you could get away without GEB Ch?
S
S
