Velox One
    Originally posted by Biogas View Post
    I found on the web three videos aubut Velo One:
    http://www.youtube.com/watch?v=fqgROvp_VZw
    http://www.youtube.com/watch?v=UQE_wM3SkhQ
    http://www.youtube.com/watch?v=MECapmy9BbE&NR=1
    Is this fake, or it's a new "Deus=GOD"?????
    Or on tests is OK, but on the ground at detecting is unusable??
    Have anyone experience about this detector?
    Thx
    Did you notice the iron discrimination was switched OFF for these tests?
    It was operating an all-metal mode.
      I have been tested in the air, but the metal detector never get to detect a coin at the distances shown on the videos. Maybe I did something wrong. Tests in the ground, I've never gotten to do, because the metal detector was not mine.
        Hi!
        I saw that! But I don'tknow what does it mean "Iron off"? All metal, or Iron detecting of?
          "Iron off" usually mean some sort of preselected notch filter, that filter out Iron signals.
          No "All Metal" search possible on this settings.
            Hi!
            I think the same thing: that isn't all metal!
              There is some kind of discrimination as the audio changes pitch occasionally, but a bit oddly. It seem as if a single oscillator is a VCO fed with discrimination voltage at discrete steps. No videos show how this device handles iron, and a choice of targets is such that every other detector would sound as on steroids.
              Audio is proportional, an it is not a bit nervous.
              Let them try Croatian coins
                velox one perfect depth and dicrimination my test underground 1 euro coin 57 cm in the ground in the air 68 cm.full power sensivity and iron reject mode.audio boost 3 and mineral elimination 1
                  Velox
                  Hi!
                  I'm skeptical sorry!
                  Can you share for us a video?!
                  Thank you!
                  Biogas
                    Hi All!
                    I found on the web this video:
                    http://www.youtube.com/watch?v=VKHuc...ature=youtu.be
                    This is with normal/useful settings (dont all metal, and don't max. sens).
                    From 4:44, is it a bad properties...
                    I think it is don't so good we in factory test...
                      Seems reliable:
                      http://www.youtube.com/watch?v=UxWpI...ature=youtu.be
                        what serch coil?
                          Cirak - I have just had to remove your post (which was placed into moderation).
                          If you want to attach an image, you need to click on the Go Advanced button, and then select Manage Attachments. You cannot simply cut-and-paste the image into your post, as all that gets displayed is a lot of gobbledy gook text.
