EPE IB detector depth problem .. w/ schematic
  • #31
    Davor, I am agreed with your ideas but problem is i cannot make other better metal detector because of The project idx-pro-vdi this was very hard and if kit of I'dx-pro-vdi obtain from silverdog.UK that's cost is more due to Indian currency so I stopped to making new projects and in the thread idx-pro-vdi, I am confused due to the information is many time modified so which PCB is better?
    Which schematic diagram is final..?
    Which component is final..?
    So many things...
    Davor I want to many help but everyone have no time to discuss about metal detector....
    Thanks for reply...
    Sorry for my talks....
    • #32
      As for IDX, pick anyone. It all comes to minor differences, and details can be trimmed. IDX is rather old design, and when refreshed with new parts there are some exotic details appearing, but easily fixed. You may try obtaining a PCB only, and source the parts locally. Also you really do not need a VDI module. It just sucks batteries, and you'll end up digging - or not - regardless of what VDI says.
      • #33
        Davor,if you are really help me than I can make this project...
        But now I want to circuit diagram, PCB diagrm which is perfect and checked plz post here
        Or davor if you have anyone extra PCB of idx than can you send me...
        • #34
          No, I don't have any. There is a large population of people that made IDX and are happy with it, so you'll surely get help all the way.
          Try checking your local suppliers if someone is making PCB-s from your designs in electronic format without charging extra for the films. You'll find such files on the IDX forum, and most probably it will be cheap enough. Cheaper than that is making your own PCB-s and it is not that bad either. You'll miss the silk screen though.
          The parts used in this project - in case you don't go for a VDI module - are quite common, and you shouldn't have problems sourcing them locally. The rest is up to you.
          • #35
            Thanks davor,
            I am trying to find files of idx..
            If you have than post...
            Thanks..
            Project (idx) start now..
            • #36
              Davor,
              I am again confuse, I got many files of idx which is take for start project....
              • #37
                Most people built a silverdog kit so your best bet is going with the stream and using the matching files. http://www.silverdog.co.uk/shop/inde...product_id=124
                Why don't you shift this discussion onto the IDX topic, this is a bit confusing here, and largely off topic.
