whites coinmaster 4000/D parts help needed
  • whites coinmaster 4000/D parts help needed
    Hey all, I have a whites coinmaster 4000/D of my neighbors that has some potentiometers that are siezed. They are centralab pots but don't list the ohm's. Any ideas on how to figure what the ohms are? This is what is on the pots: Centralab, 1348308, 121-0503-41= the DISC. pot./ Centralab, 1348222, 121-0202-51= the GEB. pot./ Centralab, 1348240, 121-0251-51= volume pot./ Centralab, 1348243, 121-0103-51= SEN. pot./ Centralab, 1348237, 121-0503-51= tuner pot. Not sure if there is a way to cross reference but any help would be great.
    Thanks, Coin
    Try this: DISC 50Kohm, GEB 2Kohm, VOLUME 250ohm, SENS 10Kohm, TUNER 50Kohm. This should be their values according to marks on their bodies.
      I can't find any values on them. The only info thats on the bodies is what I listed up above. I was hoping someone had a old schmatic and could look up the values for me or maybe some one knows where I could crossreferance the part numbers on the bodies to get the value. If I can't find out I will give your sugestion a shot.
      Thanks, Coin
        I haven't schematic of this particularly model, but I have some simply models schematics like 5000, 6000 DiPro and some else. Their potentiometers are in many case same as on your's 4000/D but not always. Each model has it's potentiometers, but if you analise marks which are given on potentiometers bodys you can find out what is their exactly values. For example the DISC pot number 121-0503-41 means 50 x 103 or 50 x 103 which is 50 Kohms. If you can't find exactly values try with approximately it can be wrong that much.
          Ok thanks a ton man! I will give it a try.
