HELP! HH RevD Coil Hookup!
  • HELP! HH RevD Coil Hookup!
    i built a coil like in the HH manual and was trying to figure out where the leads go on the circuit board. it has a 3pin junction block labled L1 and the middle pin is not labled other pin L2. can anybody tell me where the shielded part of the coil to the coax goes on the board and where the two coil to the coax leads mount.
    the instructions say connect other end of the coax to the circuit L1, with the shield solderd to the ground side and the center conductor connected to Q3. so does that mean to twist the stranded wire together on the coax and land it to L1 and the shield to ground on the board and the center coax wire to Q3 irf740? the instructions are not very detailed can someone give me better directions on the placement!
