ee teasure hunter
  • ee teasure hunter
    Who are build the ee teasure hunter?.
    I build and the max.deph in air was 50 cm is ok?
    and a money 2p at 10 cm
    Re: ee teasure hunter
    sounds ok
    i have 20 mhz and 4 mhz code for pic 16f84a that runs this one much better esp the 20 mhz
    change the xtal and flash a compatable cpu {now only a few euros to buy 20 mhz speed}
    i adjusted this way a long time ago but left it becouse the 10 mhz chips would have needed 2.5 nops to be added or make another nop loop for each nops added... to balance things.... so 20 mhz is more sutible speed
    if others need the code{i send to a few along with a pcb design in 2 colours i made } i dont mind to post it
    or perhaps carl can stick it with the rest of the bits for this one....
    but your depth is a little low
    first change the cpu then peek al parts and recheck your cap values and res decades {i do this all the time } use wrong decade esp with 5 band resisotors..
    or a cap wrong type or way round
    i recomend polyester layer for all and radial organic low res factor caps 105 deg c {not important ht variety}
    use 1n4004 diodes in voltage pump
    use 3300 cap not 1000uf cap in 9v rail main resoviour cap
    place a diode from gnd to the +pumped rail cathode to the rail {to stabalise it use a 15v zener to clamp it }
    the output of the pump is 15.5 and expects to be clamped hence the .5 volts extra above 15 by a 15 volt zener possible 1R res in series with the diode that supplies the rail from pin 6 on the pump also will help
    i found using an lm318 isnt so good
    first use lm3018 this is a far better version is cmos and uses less current
    use low current 555 ic
    make sure to use 74hct4066... or cd4066 *bp {must have buffers} {i use fets here instead of transistors to switch the stages }
    for the other optimisations
    the tl 072 use an op 02a or ne 5532
    c10 and c11 change to 10 pf for 20 mhz xtals and 22pf anyway 33 is wrong and 33 is for 10 mhz {pic 84f standard}
    the shunt rectifer diodes in4148 add ferrite beads too {3 mm long {or 5 } 2 mm dia
    to each end of both
    also add to the resistors 1w change too 2 watt carbon film ... and add again some beeds
    to the center pin of your irf840ctf fet
    r28 change to 22R + 22R in series .6 watt metal film or carbon ... is better but .6 watt
    c15 changes to 100uf
    i used a regulator small 78lm05 type to92 as a supply for the cpu
    sounds overkill but why waist 1 % of 12V buring a resistor.... all the time
    this made the cpu realy stable
    appart from this
    more like 20 - 40 cm with a {copper 2p or copper coin} in air is a good target
    once tuned
    the other side of the room waving it about should trigger it also {cuting flux}
    also make sure to check which way you set the coil { i mean which conections to where } try the coil the other way round
    email me for 20 mhz {very stable and a lot better} code or 4mhz code {what you expect from 4mhz}
      thanks simeon
        i have 8 mhz code for stuart pi 84 also {nice.....}
