The threshold circuit looks to be your Achilles.
Sort out your threshold and critically dampen your coil and you'll easily get nickels at 14 inches in the ground.
Look out here come the blisters..................:-)
P.S. If you do the trick with the trimmer best to use a 1k2 and a 10k trimmer, seems your coil is pretty fast so that will give you a bit more headroom.
Cheers
Cheers
