Calibrating the gradiometer to measure weak magnetic field
  • Calibrating the gradiometer to measure weak magnetic field
    I had built Fluxgate Magnetometer based on Carl's article.
    http://www.geotech1.com/pages/mag/pr.../fmx1/fmx1.pdf
    I ordered the parts from Fat Quarters Software and received the complete package. I assembled the complete equipment based on specification provided and the equipment is working in terms of detecting weak magnetic fields with two sensors oriented in same direction with 18" apart in a plastic enclosure. I am not using the feedback point of Fluxgate sensors.
    The main challenge I am facing is to calibrate the VCO output ranging from around 250 Hz to 1124 Hz range as I don't have any reference field.
    The oscilloscope (VCO output) doesn't show any frequency beyond this range in case of no field or high field near a static magnet.
    I intend to measure the field in micro Tesla range and calibrate the output of VCO into a display to measure the oscillating magnetic field intensity around a circular coil with multiple turns and measure the gradient based on distance from dipole moment.
    Please help in providing some pointers and your prompt reply would be highly appreciated.
    Thanks,
    Manav Singal
