Ideal PI coil current
  • Ideal PI coil current
    I am working on a CCPI circuit but just want people who have a little more experience with MD circuits as to put forward their ideas what the 'ideal' coil current should be.
    I have been setting it around 1.8A at the moment, but if it doesn't need to be that high I can have a lot shorter pulse widths and will get better battery life.
    Not sure anybody knows the answer to this. To build a bigger field and thus go deeper you
    want the biggest current you can manage. A large field can magnetize particles in the ground
    so that you cannot see as deeply.
      I figured as much. Do you know what current model PI machines run, ignoring pulse shape, width etc? ie ML machines vs Whites etc?
      Would using a lower current, even though depth may be sacrificed a little, be better for use in highly mineralised ground?
      Perhaps it may be useful to allow the value of the CC to be adjusted to allow for different ground conditions?
        No idea what current models run. The limiting factor to me is how deep do you want to dig.
        (And what size object do you want to see how deep?)
        On a beach looking for gold necklaces you might use 5 amp pulses (very short pulse) but
        in other places you might want to turn it down to 1/2 amp to see more clearly. The big problem
        is how to set it up in the field?
        So a variable setting would be useful and max power is as much as you can give for a reasonable
        run time without anything overheating...
          I recall the TDI runs around 2A, Minelab may run a little higher.
            Thanks for the replies. I think I am going to experiment with a variable CC circuit and see what the 'real world' results are. I have access to some light weight battery packs that come in various voltages (used in some of the items I repair) that will allow me to move away from the 'standard' 12v battery pack I seem to see in most MD circuits. I am just waiting for some soic to dil adapters to arrive so I can use some ic's I have in a breadboard for testing.
