Pulsdetektor Miner 2
  • Pulsdetektor Miner 2
    here a file which i had laying on my harddrive
    maybe that it contains some little errors (watch for all wire links)
    i hope someone has time to place all parts and number in sprint layout
    Miner2.rar
    here the additionel Infos you Need
    http://www.pulsdetektor.biz/html/miner-2.html
    Supply Voltage : Nicad/NiMH 21.6V/2Ah
    Pulsepower : 510W/yS
    Operating current : 220-450mA
    Display : 128x64 Pixel/Led
    Keyboard : Foil 3x4 Pads
    Disc : Yes
    Penetration(28cm/Spule) : 180 cm
    Penetration(50cm/Spule) : 220 cm
    Penetration(100cm/Spule) : 320 cm
      Disc : Yes
      hi bernte
      why dont make miner4
      if decide to make tell me. but hex file is demo not complete.
        it is tested an known as working
        and i dont have a good layout for miner 4 in sprint layout or eagle or soemthing else
          i think have layout for miner4
            hello mohandes
            did you have a good layout in any layout software format or this terrible black white image from the miner4 pdf file?
            if you have the bw image i should be re-worked before you build it
              hello mohandes
              hi
              i will check my hard derive on PC and send here.can you improve it?
                layout can be improoved
                it can also be updated to more common components which are easier to buy
                for example the bi directional diodes or the mosfet and the one opamp which is heavy to get
                  hello mohandes
                  This board is in SL6.
                    hmm looks good
                    is it from you, or from a user of the old pulsdetektor.de forum
                    i lokks similar to something i have seen before
                    many thanks for posting
                      almani.zipalwmani.rar
                      see my friend
                        hmm looks good
                        This PCB I made using the template(scanned copy - bitmap) of pulsdetektor.de. It is the same as the board of Miner2, but there are fewer elements in the lower right corner. Note that I have not shown SMD capacitors which are mounted on the bottom PCB under IC9 and IC10. I have not shown and two double acting diodes that are parallel to the P5.
                          hi Toros
                          please put here your changes and if you can write in lay fine name of parts.
                          Edit:
                          i forgot ask you about this detector , have stability and is deeper ? more data put here
                            [QUOTE=mohandes;200108]hi Toros
                            Mohandes, no need to schedules elements on board as the file miner4bs.jpg contains all the correct information that is needed. As I noted above board was taken as an exact copy of the publication in pulsdetektor.de. It is identical with the board of miner2, but there are fewer elements. This is clearly visible when comparing the two files miner4bs.jpg and minerbs.jpg(look at the Miner2 dokumentation).
                            I've made only Tiny of pulsdetektor.de detectors. I am not satisfied with the result. The sensitivity is lower than that of the detectors Barracuda and SMPI.
                            Tiny is a slow detector and can be compared with the other slow detectors like Sandbanks. Sandbanks is simple and easy to setup and I think it is more sensitive. The best modification of Sandbanks you can find on the site of Lucas Lab:
                            http://www.lucaslab.grandhost.pl/luc...krywacz_PI.htm
                            Detector documentation can be downloaded pull here:
                            http://www.lucaslab.grandhost.pl/luc...z_PI/pliki.rar
                            Other German detectors contain elements that have long been discontinued and can not be found in the market. This requires the use of substitutes and the board must be changed and the individual items to be restated.I figured I could not handle such a task. I hope that someone else will succeed and publish his thesis here. Maybe this will be Bernte one, which has no problems with the German language.
                              Bernte one . how do u do?
