Is it possible to link a Minelab X-Terra 705 to a cordless headset using Bluetooth technology?
  • Is it possible to link a Minelab X-Terra 705 to a cordless headset using Bluetooth technology?
    I have a MineLab X-Terra 705 and a cordless/Bluetooth compatible headset.
    Does anyone know if there is a Bluetooth accessory that would fit onto the earphone jack on the X-Terra which will send Bluetooth sound signals to the headphones?
    This will allow me to use a cordless headset.
    Thank you,
    Pete.
    Hi yes you can but bluetooth will give you a delay which will be annoying you should try something like this on fleebay 121516990356
    2.4ghz no delay and it has a small enough transmitter to mount on your shaft somewhere
      C. Moreland did answer on this, there is hight speed bluetooth of new generation. but what - was not given a link. so this BT has to be only nice
      for using in md.
      old BT is bad for md because low transfer speed ie the delay, new BT is good.
