VLF Coil Interchangeability
  • VLF Coil Interchangeability
    Hi guys,
    I have a question regarding VLF metal detectors:
    I already purchased a VLF metal with a 200mm concentric coil. Just wanted to know if it is possible to change the coil to a bigger size for deeper detection depth?
    I have done some research and some websites suggest that you can change coils, but can you use any VLF coil interchangeably?
    Really appreciate the help
    There is little compatibility amongst different brands of detectors, and sometimes even models. You'll need to get a coil specifically for the model detector you have.
      Hi Monz,
      you can found many informations about your question in the book "Inside the metal detector" of Overton/Moreland at chapter 10.
      Originally posted by monz View Post
      Hi guys,
        Tell us what machine you have, then maybe someone here will have more specific advice about coil compatibility.
          Hi, its a MD3006
            That's a Chinese model, probably no other coils available for it.
