FPGA
  • FPGA
    Is anyone doing anything with Altera or Xilinx (VHDL) platforms instead of using a microcontroller.
    Hi DavidB,
    I have used an Xilinx platform design for PI detector in the past but the cost and availability of DSP processors these days I personally don't see any real advantage.
    While you can have a virtual custom or standard IP embedded on FPGA, use an external ADC etc and have a wonderfully slim lined PCB, my view is this.
    Unless you use these things (including VHDL) every day or proficient in coding, don't bother
    Unless you are going market a product, the numbers don't stack up.
    On the flip side'
    If you are proficient or have a liking for FPGA, then go for it!
    I dropped the idea for a commercial unit simply because the devices I was using at the time was dropped from manufacturers line up, not once but twice, a real pain when PCB designs are done.
    If you do go this path, I recommend designing a daughter board standard with the FPGA on it, all other circuits on a motherboard.
    Good luck with it anyway.
    Brian
      JL King was experimenting with one here.
      http://www.geotech1.com/forums/showt...ed-PI-Detector
