which WH1602B
  • which WH1602B
    Building a Quasar ARM and need to order a LCD WH1602B
    The variety is bewildering.
    Need to work from minus 5 to about 35 centigrade.
    Readable in bright sunlight.
    Low power consumption
    The board has a separate regulator for the LCD so can be 3 or 5 volts
    Does WH1602B-YYH-JT look okay
    I use cheap chinese 1602 lcd, doesn't have a brand, its work with chance, felejo and krot-m
      Been reading up on LCDs
      To make it easy readable in bright sunlight I think I will need "transflective" and "12 o'clock viewing"
      Is this correct
      Does it make any difference if its 3.3v or 5v
