I know this would work but here goes.
The nice feature of the TDI is the conductivity switch and how you can reject certain metals from high to low.
Why not make an adjustments to where the low-high takes place without adjusting the ground balance.
This could by easily done through digital programing but not sure the TDI has the available electronics.
Maybe an adjusting pot tied to the switch to include or exclude the upper or lower portion of the switch setting.
At present with the ground balance set to 7 1/2 the breaking point between high and low conductors might be:
A pull tab and below gives a high tone (low conductor)
Just above the pull tab gives a low tone (high conductor)
Make an adjustment to change where the low tone starts at a level below the pull tab without adjusting the GB.
