Ask for help Surf PI 1.2
  • Ask for help Surf PI 1.2
    Ask for help Surf P.I1.2
    Hello.
    I'm from the Czech Republic, I set up a Surf 1.2 detector that does not work very well.
    It does not have a good depth range (tried several coils, and still the same). Another problem is that when approaching the metal (about 3cm) the signal is interrupted instead of being the strongest. All measurements on the integrated circuits are managed, set to 0V
    on NE5534P. I have original circuit board from Ebay, so it should not be a mistake. Maybe R18 and R20co I have read to be opposite. I do not know what can you please help somebody? Thank you very much. I speak English, it is translated from Goglu.
    We do not know what schematic you used, or what PCB you have.
    Check you have the correct coil
    damping resistor
    delay
    battery voltage
    what type of battery's are you using , are they at least AA's
    What did the ebay seller tell you when you asked for help ?
      ORIGINAL board??? lucky boy. i would like to see your original pcb.
        The original record is not, of course, sorry for the bad formulation, I meant that the board is not a domestic production.
