Testing if everything is OK with the XLT and its coils
  • Testing if everything is OK with the XLT and its coils
    I now have some measuring equipment from building stuff with lots of help from this forum.
    In the light of Whites appearing to be going by the wayside I thought I might as well
    go about learning how to test all XLT parameters. I still love using it, especially with the bigfoot coil.
    I would like it to last as long as possible of course.
    Some questions:
    - What should/can I test to see if everything is up to par?
    - Is it known if the microcode in the CPU of the XLT is susceptible to "bit-rot"
    - Anything else I might not be asking, cause I just don?t know ...
    Cheerio, Polymer
    I don't know how you would test it other than the obvious: ferrite for ground balance, various targets for sensitivity. I've never heard of any problems with the micros (there are 2) losing their minds. A common problem is that the displays eventually fizzle. I took my XLT to White's last week and got the display replaced. Repairs are 'no charge' for walk-ins. At least until Friday.
      I don't know what micros are inside the XLT but while browsing ATmega2560 datasheet the other day I saw an interesting paragraph which said that projected data loss is much less than 1 ppm over 100 years at 25 C. Some STM micro I looked at had similarly insane numbers, making it seem like not an issue to worry about. Have there been cases of MCUs losing their programming making you ask this?
        Thanks for your reply Carl!
        I have no experience with testing a VLF IB like the XLT. So even the obvious is more than a mouthful for me.
        More to learn - I will see what I can find on the forum about ferrite / ground balance testing.
        Alas, Europe is a bit far from Sweet Home ...
        You Lucky Ducky - walk-in and repair. My display is still working fine though.
        The backlight went funny years ago causing EMI, which I disconnected.
        I believe there is enough information here about the lcd to get one may the case arise. Wouldnt mind having a spare in my parts box though.
          I have experienced it with picture files.
          The manufacturers must have a reason for disclosing this. Semiconductor structures are getting smaller all the time.
          Perhaps its litigation protection if something serious fails with loss of life.
          1 ppm per 100 years sounds sorta neglegible, but one "funny" bit and your application is most likely toast.
          Consider say just 1 Gbit and the magnitudes change.
          Maybe other parts fail before this happens - in light of faster and faster cycle times (product wise).
          Perhaps no one notices that maybe it is this phenomenon and a pcb/product is just binned/replaced.
          Yes, I have a penchant for quirky and not so common stuff.
          Here two interesting reads if you like, also to wearout:
          https://betterembsw.blogspot.com/201...m-wearout.html
          https://en.wikipedia.org/wiki/Data_degradation
            i restore videos now after as ytube destroyed my channel https://www.youtube.com/watch?v=fMBd...ature=youtu.be
